Clean those ears! Product review...
steveinaz
Recently bought the elephant ear ear washing system. AWESOME. Just use warm water. I can't believe the meteors this thing hosed out of my ears. You need to do it a couple of times, then the wax balls will start falling out. This is NO gimmick, this puppy works very well. I think it was $29 bucks, worth every penny. It has replaceable tips.
Idk, looks scary! What about, never stick anything in your ear, except your elbow?!?
Thanks for the recommendation Steve, was thinking about getting this done soon.
I got some ear drops that turn your ears into a volcano when they are all waxed up. I would be very careful with that contraption, looks like it could blow out your O ring if you get trigger happy!
Looks interesting. I bet a lot of CP members here could use this!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
It's awesome. I use 1 part hydrogen peroxide to 3 parts warm water.2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
HT: All Polk: SDA 2.3tl fronts, CSiA6 center, 500-LS ceiling, RT/FX, RTi8, Monitor 4 rears, plus Yamaha CX-a5100 AV Preamplifier/Processor, Yamaha MX-a5000 11.1 channel amplifier, and Sony XBR55-AE1 OLED TV. -
To blindly do this is something I would not endorse.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Correction. 1 part hydrogen peroxide to 4 parts warm water. This is from their website: http://www.elephantearwashsystem.com/earwash-instructions.html2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
I lay on my side and put a couple drips of hydrogen peroxide in my ear and then sit for a few and let it do its thing. Then I rotate so the ear drains and flush it out with warm water from a syringe."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Not me i use a stick....
On my drill -
On my drill
Hammer Drill?
On my drill
Hammer Drill?
Now you're just being silly -
My ear wax doesn't discharge properly aND it becomes impacted. I go every two months to have my ears cleaned. This involves picking the impacted wax off the drum and vacuuming out the excess moisture. Sometimes it's worse than others and can be painful. I have, on occasion, used a peroxide and water rinse to help between visits. This usually ends up causing more problems than it cures. My doctors do not recommend rinsing as it can upset the delicate pH balance inside the canal, and, any residual moisture becomes a breeding ground for fungus. I know this first hand all too well.
Looks cool, but, I wouldn't do it without consulting your dr first. -
I have had one of these for years. Same item my doctors office used when I had a wax blockage. I just use warm water. Peace. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
In my 4.5 years here, I've never been offended, never been hurt, I've gotten irritated a couple times, but this is the first time I've been disgusted. This thread has completely grossed me out. You guys need to get together and start a colonoscopy thread sometime, or maybe a thread on infected sinuses. Maybe throw in a diarrhea thread while you're at it. Groddy!
In my 4.5 years here, I've never been offended, never been hurt, I've gotten irritated a couple times, but this is the first time I've been disgusted. This thread has completely grossed me out. You guys need to get together and start a colonoscopy thread sometime, or maybe a thread on infected sinuses. Maybe throw in a diarrhea thread while your at it. Groddy!
Now that you mention it, I have been suffering from diarrhea the last couple of days. Thank you for you concern. -
The GP I use to go to used a rinse when it got bad. The ENT dr's I now go to strongly advise against it for the reasons I mentioned.
I would expect an ENT to recommend against solutions like this since it potentially takes you out of their office. I’m not saying their opinions isn’t valid, but is one that should be taken with some degree of skepticism.
Most of the time it is ok, however, I have seen problems with this, including perforated tympanic membranes. Also, sometimes if the wax can get lodged against the drum which is a PITA to remedy.
Also, some people experience a significant amount of vertigo with this.
At my work, when I clean out ears via irrigation (which is my least favorite technique), I use a pigtailed catheter to allow for turbulence to occur within the ear canal. With a "BLIND" technique such as the above, there is not what I see to be a curled end which could mean a direct pressure against the TM.
Most of the time you'll be OK. But when you do it wrong....
You can kiss your speaker system journey goodbye.
Tread softly.
Just my MD advise.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Y'all know it's not really "Wax" right?Home Theater/2 Channel:
dhsspeakerservice.com/ -
Yeah, but it's much easier to rhyme than cerumen. You need to clean the wax out to listen to your stacks of wax, FLACs, and CD tracks, but check with your doctor first.westmassguy wrote: »Y'all know it's not really "Wax" right?
I'll bet Zappa could have thought up a few very INTERESTING uses for that device..LMAO!.. -
Try 1 drop of mineral oil and lay on your side for 20 minutes or even better, just before your nap if you are retired. Longer process but it has worked for me. Advice from Dr. Oz.Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
I've done the thick-liquid murine peroxide drops, et, etc...it's a lengthy process. This works very efficiently, but COMMON SENSE applies. Start off slowly, and make sure the water is very warm. Squeeze the trigger at a moderate rate.
This is more intended for maintenance, not clearing impacted wax. Again, common sense is your friend.
These are used by a number of ear doctors, BTW.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I went and look at some reviews on amazon. I blame you @steveinaz for what I saw! It may not be INTENDED for clearing impacted wax, but that sure looks like what it does for lots of folks! To quote Jimmy Fallon, ewww!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
It worked really well for me. It's rare a product like this performs as well as they claim--but it did for me.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Summer's Eve for the earsMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I dunno man....looks like a breast pump for men to me.
Looks like it could work though.HT SYSTEM-
lsi 9's -
I think Kramer would call it the "Mans-Ear".
I could be wrong.Sal Palooza -
AsSiMiLaTeD wrote: »I would expect an ENT to recommend against solutions like this since it potentially takes you out of their office. I’m not saying their opinions isn’t valid, but is one that should be taken with some degree of skepticism.
Everything the ENT told me has been proven correct. I'm 52 and have been getting my ears cared for for this same thing for well over 30 years. -
mrbigbluelight wrote: »I think Kramer would call it the "Mans-Ear".
I could be wrong.
LMAO.....correct you are !HT SYSTEM-
