Sigma S1 - Volume level
KarlG49460
I just hooked up my new sound bar and after watching a program on Netflix for a few minutes, the volume increased without being adjusted via the remote. I turned it down to the desired level, but again after a few minutes the volume increased without being turned up. I'd like the volume to remain "constant" unless I decide to turn it up or down. Any ideas how to correct this problem?
Hello,
I'm not sure what could be causing the volume to change on its own, unless the program or source changed. It's probably best to contact Polk at 1-800-377-7655 select option 1. -
I had the same issue with the volume turning up randomly and not being able to turn off the sound bar. When I tried disconnecting the subwoofer by holding the Bluetooth button and volume down on the sound bar it disconnected the subwoofer and the problem went away. However, now I can’t use the subwoofer.
I have the same problem. Originally connected via HDMI so I connected via opti cable and same problem. Contacted Best Buy less than a month later and the so great to be said sound bar couldn’t be returned! EXTREMELY DISAPPOINTED AND AS MUCH WITH BEST BUY!!!
