Omnis S2 Connecting problem
JanNL
I REQUEST A REACTION BY E-MAIL, OR VIA THIS FORUM.
I live in Europe, so please respond first with a battle plan I can try, before you ask me to call (and spend my money on a long, long-distance call).
Previous questions by e-mail remained unanswered.
I can't connect my Omni S2 to my router: ZTE ZXHN H369A.
When connected to power:
- Amber led in fronts starts flashing a couple of times and then turns solid for a moment.
- Then the amber light goes off and the white led at the back starts blinking fast.
- After a while, the led at back goes off and the white led at front goes on a moment.
- Then the Amber light starts flashing again...
It does this over and over again.
I can do nothing tot stop this repetition/loup.
- not holding the wifi-setupbutton,
- not inserting a USB to update,
- not connecting it to an audiosource with an aux-kabel
(sound builds op when amber light in front is on, but stops when white led start flashing)
Didn't receive a suggestions to my earlier request.
Hello,
I'll forward your email address to a friend at Polk who specializes in wireless products. -
...had one e-mail, but no step closer to a solution.
Have you responded to the email?
