Polk Magnifi One Sub Cracking and Cutting Out
Hi,
I just purchased a Polk Magnifi One from The Source about a month ago. I've noticed the sub has begun to crackle and pop, as well as cut in and out, especially at higher volumes. Any idea what this could be?
    txcoastal1 Posts: 13,518
    I think it's broken
  • Hello,
    Welcome to Polk's forum. As a test try turning off your computer router (assuming you have one) and see if things sound better. The symptoms you've described can be caused by interference from your router.
    Regards, Ken
