The search for the perfect listening chair is over...
124»
    VR3 Posts: 29,756
    true that... nothing worse than the cheap lids that come with the HD buckets, you will fall right in!!
    mhardy6647 Posts: 35,562
    marvda1 wrote: »
    these were all the rage in the 80's at the highend audio stores, I had two in my listening room.
    Ther're a couple in my basement :p The thing I hate about them -- they take up more space folded up than open! Plus, the fabric wears after a while and eventually the bottoms rip open when sat upon.
    Other than that, they're great, I suppose.
  • 55LS70
    55LS70 Posts: 184
    Tony M wrote: »
    I had one of these originals for years. And why I gave it away as a gift is something I've been regretting for a long time. It's value back then was about 750.00.
    Yes, I had the foot rest to match. :'(
    https://www.houzz.com/product/91248492-eames-lounge-chair-and-ottoman-by-herman-miller-walnut-color-indigo-open-line-midcentury-armchairs-and-accent-chairs?redirect=-1&m_refid=Bing_PLA_HZ_91248492&msclkid=a0930c8695a4165e041157bd76a8f6a3
    I currently use an Eames chair, along with matching foot rest, and consider it one of my rig's components. When I got it, my wife got the idea that it was going in the living room. I had to hold my ground to convince her to let me take it down into my "listening room". They are a nice example of mid-century modern furniture. Now I couldn't imagine listening without it.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
  • BlueFox
    BlueFox Posts: 15,250
    Nice recliner, Mikey. For a while I was using a Lazy Boy, but eventually felt the huge, cloth, chair was absorbing too much sound. Now I have a leather Scandinavian type recliner, which seems better sound wise.
  • Mikey081057
    Mikey081057 Posts: 7,127
    It's Sofa King Comfortable
    Garage | Polk Monitor 5B's
    sofa king cat...
    35904589074_a9278d1dcd_b.jpgsofa king cat 2 by Mark Hardy, on Flickr
    Clipdat Posts: 13,105
    Ringed tail!
    treitz3 Posts: 20,365
    Glad to have helped make you spend your money Mikey. Happy listening.
    Trey, you need to work on your chair man. You upped your game on the system but dude....that chair!
    F1nut Posts: 52,406
    marvda1 wrote: »
    Horribly uncomfortable chair.
  • aprazer402
    aprazer402 Posts: 3,466
    ^^^Agreed. Those are like sitting in one of these old playground swings.
    Tony M Posts: 12,027
    160 lbs. and below, they're not to bad. From what I remember. :#
  • aprazer402
    If Eames are in your budget, they seem to be popular and have the cool high-end design factor. I would like to try one someday. If not I'll have to try another nice alternative. https://www.nfm.com/DetailsPage.aspx?productid=46936332
  • BlueFox
    Tony M wrote: »
    LOL. I was visiting a friend in Galveston and we went to a restaurant/bar on a pier, and a fat couple came in. The guy sat in one of those chairs and it ripped under his weight. Fortunately, the pier didn't collapse when he hit the floor.
  • verb
    verb Posts: 10,176
    Tony M wrote: »
    I can't remember when I weighed 160lbs! :smile:
  • web_traveler
    A few years back I had to spring for a good one for my office. I started with a Herman Miller Aeron chair. Lots of good reviews. When I got it home, I sat in it for 15 minutes and my legs were numb for three days.
    Turns out that this is a known problem. There is even a website called "Aeron chair sucks.com". Most of their users are happy campers but for the percentage that can't tolerate them, they REALLY can't tolerate them. I turned out to be one of them.
    I called Herman Miller and they confirmed that I had adjusted it correctly. Then they said " our chair does affect some people that way". Then to top it off, they refused to take it back....but they offered this wonderful advice; " you can try another model of our chairs!"
    No thanks. Fortunately, after some wrangling with the store where I purchased it from, they did take it back.
    I ended up finding a Human Touch Perfect Chair PC-420 store and got this great chair! Not inexpensive...about the same as the Arron chair...but more adjustable, more Comfortable, and no problems.
    That's an end-game chair! ;):pB)
