speaking of bamboo record players
https://www.whathifi.com/news/tri-art-bamboo-turntable-eco-friendly-way-to-enjoy-music
sprout-bamboo-turntable.jpg?itok=fQsfT3mN
Polyvinyl chloride ain't too environmentally friendly, so I guess we can make up for that, somewhat, with a "greener" turntable.
  • teekay0007
    teekay0007 Posts: 2,288
    Hay, that looks just like the one the Perfessor made, strongly endorsed by Gilligan...the Skipper too!
  • dromunds
    dromunds Posts: 10,160
  • Mikey081057
    Mikey081057 Posts: 7,127
    Lest we forget the original audiophile Fred Flintstone
    Garage | Polk Monitor 5B's
  • vcwatkins
    vcwatkins Posts: 1,992
    edited April 2017
    That is cool. May sound like ****, but it's very cool. Love bamboo.
    Can't say "p00 p" ? Wow.
  • Mikey081057
    I would play this vinyl
  • halo
    halo Posts: 5,619
    I believe that it's more viable to resurrect/refurbish an old 'table than it is to buy a new one. YMMV.
    mhardy6647 Posts: 35,372
    as if I am going to disagree? ;)
    23920650610_2785af6a2c_b.jpgDSC_2460 by Mark Hardy, on Flickr
    In seriousness (well, you know, kinda...), there is one potential problem with buying used turntables (compared to electronic components). There are numerous (at least several) precision, moving surfaces that are subject to normal wear and/or abnormal wear (abuse). Besides the obvious (i.e., the belt on a belt drive platter), for a vintage "normal" (swingin' arm) tt, one worries about the condition of the tonearm bearings (wear and play) and the platter bearing. One also worries about lubrication (of the main bearing at least; for semi-auto and auto tts, of multiple moving parts). In classic, vintage record changers (e.g., DUAL, Garrard), the mechanisms 1) are very complex and 2) have a tendency to gum up severely over the decades.
    More modern linear-trackers have plenty of interesting things to go wrong, too -- especially the earlier linear trackers with rubber drive tires (e.g., the Rabco arms).
    In other words, there's a lot to go wrong in vintage hifi components with moving parts (turntables and tape decks, first and foremost).
    Sorry :blush:
  • StevieB
    StevieB Posts: 257
    Sorry :blush:
    I inherited an old Technics sl j2 linear table with a basic AT cart of some sort, IYO would a nice Grado p mount be too much to spend on such an old table?
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • Unknown
    edited April 2017
    StevieB wrote: »
    Sorry :blush:
    The Black is still available in P-mount, yes? If the tt is basically in good working order, I wouldn't hesitate to throw a Grado Black on it. No warranty express or implied, though ;)
  • StevieB
    StevieB Posts: 257
    [/quote]
    Yes it is, and thanks.
  • afterburnt
    afterburnt Posts: 7,892
    teekay0007 wrote: »
    Did you mean "Professoranmaryan?
  • mikeyb128
    mikeyb128 Posts: 2,885
    I've read about lots of great benefits about bamboo being used for audio applications, and often compared to that of carbon fiber. So this table might not sound to bad at all.
    Found this interesting article:
    What makes bamboo so effective in the audio world is its structure and the process that allows us to turn what is basically a massive fibrous grass into a flat board. The bamboo itself is formed from long bundles of cellulose fibers, bound together by lignin, a natural thermoplastic resin. The closer to the surface you get, the greater the density of those fibers. The result is not unlike natural carbon fiber, but considerably heavier. Take that structure and cut it into strips that can then be stacked face to face to create a single flat board and you have a random, composite, variable-density material -- which is just about ideal for dissipating mechanical energy effectively without converting it into a single, dominant resonant frequency the way that glass or MDF does. Great in theory -- how does it work in practice? Better than you are going to believe -- which is exactly why Atacama and Quadraspire have made it central to their product lines.
    2 channel:
    Theater:
