Right channel issues again
I-SIG
I-SIG Posts: 2,243
edited April 2004 in Troubleshooting
This evening, I decided to re-arrange my room so that my new Parasound wouldn't have any gear stacked on top of.
Once I fired the system back up, the right channel was gone!
This is too similar to what happened with that Carver TFM-42. The stereo was simply working last night and then the right side is gone. :mad:
Maybe there is something going on in my AA DLC preamp? I have two sources and that ain't it. :confused:
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2004
    Should I start beating on stuff?
    Wes
    VR3 Posts: 28,820
    edited April 2004
    I HEAR YA MAN!
    I have no help for you, but this happened to my GFA-545 II, the right channel just stopped working. Let me know what you find!!!
    It sucks, I feel your pain!
  • dorokusai
    dorokusai Posts: 25,577
    edited April 2004
    I would get the system simple, and start from there. Drop everything but the pre-amp, CDP and the amp. If it happens then, start checking cables. If it is happening on the right side....the swap every cable asscoiated with the right with the left.
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2004
    Mark,
    Right now, that all the system I have! I can't go any simpler.
    I'll do the cable swap deal Tuesday night. Gotta watch the Ramblin' Wreck beat UConn again tonight!
    Wes
  • dorokusai
    edited April 2004
    Wes - Oh hell I didn't know that :D Yea, let me know what happens, I would expect a bum IC....but stranger things have happened. Have fun!
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2004
    Mark,
    You would be correct. One of my nice little AQ Copperheads has apparently bit the dust. Luckily, I had a higher-end pair of Monsters laying around to fill in for now.
    Life is good again, but I can hear a difference with the Monster in the there. Not quite as smooth, although I think the bass may have improved, but that might be simply having a good connection to run through as well.
    Wes
  • warviper
    warviper Posts: 585
    edited April 2004
    Did you junk the carver for no reason then?
    Wish I was a polkologist then I could call my self Dr.warviper.
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2004
    Possibly, but what's done is done. I'll admit to probably being a moron about this, but I'm sure some of y'all have been down my road before. Oh well, live and learn. Besides, this would likely fall into one of life's cheaper lessons! ;)
    Wes
  • dorokusai
    edited April 2004
    It's fixed, so that's all that matters. Glad to hear it Wes!
