KODO drum music
I want to thank the person that recommended the KODO CD. I don't remember who made the recommendation. I have enjoyed the CD for many years. I also play the CD to find/locate things that rattle in my main listening room. Turn the CD up load and walk around the room to hear the rattling, windows, doors, hanging pictures, heating pipes and nick narks.
    treitz3 Posts: 20,072
    edited April 2017
    If you like that one, may I suggest two more?
    Specifically, songs 1and 2
    Specifically, song 10
    Is this the KODO you have?
  • bikezappa
    bikezappa Posts: 2,463
    Yes I have both of those CDs. The drum & track is old. Wonder where I put it?
    Not many KODO CDs.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    bikezappa wrote: »
    If you're using their music as stated, versus critical listening, I might suggest iTunes. By my count, they have 15 Kodo albums available.
    I'm going to go on a rattle hunt later today, thanks for the info!
    txcoastal1 Posts: 13,519
    edited April 2017
    This is one of my reference percussion DSD's that I use for speed, attack, and decay
    https://yarlungrecords.nativedsd.com/albums/smoke-mirrors-vanish-vol-2
    SMOKE & MIRRORS VANISH VOL 2 (2013)
    TAKEMITSU, RACHMANINOV
    SMOKE AND MIRRORS PERCUSSION ENSEMBLE
    1. From Me Flows What You Call Time
    Takemitsu
    This album was recorded to Analog tape. It was then transferred to the DSD
    We used two coincident Neumann U47 microphones for the orchestra with two AKG C12 microphones for a small amount of reinforcement for the winds and rear percussion in the Takemitsu concerto. We chose a single stereo AKG C24 microphone for all the other tracks. Jon Fisher from Gearworks Pro Audio lent us these precious microphones. Elliot Midwood designed our microphone preamplification equipment and we recorded directly to RMGI 468 tape using stranded silver Yarlung interconnects and the Yarlung analog tape recorder circuitry designed for us by Len Horowitz. Mastering by SteveHoffman.
    Do you mind bringing it with you at LSAF?
    treitz3 wrote: »
    I'll put it on a stick for you
