Is my rectifier blown?
hochpt21
hochpt21 Posts: 5,423
edited February 2017 in Electronics
Went to play music and there was only faint sound. Looked at the Dared and the rectifier had no glow.
  • That happened to mine once,, popped in a new one and good to go,,let us know what you discover
    Looks like it to me, of course the question is....why ? Like George said, pop in a new one but I would still wonder why it blew.
  • hochpt21
    I don't have another one to test. I left the preamp on for 4 days, which I don't think is recommended, but didn't think would do any damage.
    I'll have to get another one and try it out.
    pitdogg2 Posts: 27,547
    Tubes are too expensive to just let burn away. I understand leaving it on for awhile but 4 days?
    I always try to keep some spares
  • hochpt21
    I hear you.
    Does the black on part of the glass near the base of the tube signal damage? Or is that just part of the tube..
  • Can you test it?
    heiney9 Posts: 25,576
    Many times it's very hard to look at a tube and see it's no longer functioning. The blackish/silverish stuff at the bottom is actually the getter material since the getter is in the bottom of the rectifier, normal.
    That tube is almost 60 years old, it happens, not often but it happens. That's the best 5Z4G on the planet. Find a replacement.
    I'd try a more readily available one for awhile to make sure it's not a pre-amp issue. A 5y3 will work as well and are a bit more plentiful to try as a test.
    Having tube gear has certain caveats that go along with it, just like owning a sports car. They can be a bit temperamental at times and you just have to accept that. One of the reasons I have so many spare tubes. I've only had 1 tube go out on me, a Winged =C= 6L6 power tube and it just started to distort and I smelled hot plastic. Shut it down before it did any damage.
    All other tube issue were present at power up. I've recently had a shorted signal tube, I've had very distorted signal tubes and even (2) where the getter was broken off inside.
    **** happens.
  • hochpt21
    Don't have a tester or a backup tube. I took it out and then re-seated it, and when I turned the pre back on .... no glow again.
    I'm thinking it has to be the tube.
  • If you can wait a couple of days,, I have some NOS 5Y's in the attic that I can send you for the price of shipping,,if so,,pm me
  • hochpt21
    Wow, thanks for the kind offer. PM sent.
  • hochpt21
    I'm a bit of a tube noob and I've been reading quite a bit tonight, trying to figure out what might have gone wrong. Someone said that the rectifier is supposed to help "protect the unit".
    We had a power outage last week while the unit was on and the breaker blew. I turned the unit off and reset the breaker and then the unit worked fine, but I wonder if that power outage played a part.
    A tube that old can go at any time. Like Brock stated many have that material it's a normal part of many. IIRC its a barium flashing. Go to eBay get your look on. You can also google it to find many other sites and buy a few.
    Is your rectifier blown ?
    On second thought, if it's not smoking a cigar with a glass of Jameson next to it.....chances are no.
    You're just wrong T
    Before you give up, maybe clean the pins and re-insert and try again. Dirt, corrosion and poor contact in the socket causes all sorts of issues. I've had rectifiers not work until I wiggle it a bit or clean and re-insert.
    If you are getting faint sound then there's hope it's not blown, but just making poor contact.
    When I have a tube issue, which isn't often, I always clean pins and re-insert. Most times this eliminates the issue.
    Like I said, sometimes they can be a bit finicky.
    Good luck
  • hochpt21
    Thanks everyone.
    Brock, I'll try that tonight.
    I wouldn't leave it in too long if it's still not functioning correctly. You'll know in the first minute or so.
    mhardy6647 Posts: 35,364
    heiney9 wrote: »
    Yup.
    ahem.
    In seriousness, I might (???) have a spare used 5V4 collecting dust in the basement; let me know if you (the OP, that is) want me to "check stock". If I have one (and if it tests good!), it can be yours for the cost of postage (you're in the US, yes?).
    msg Posts: 10,532
    I was expecting to see ten jokes in this one before any actual tech, but no, right to it. You guys must be a real barrel of laughs at parties.
  • hochpt21
    msg wrote: »
    Lol...I kind of threw the title out there expecting some fun.
    @mhardy6647 thank you for the offer, but @george daniel already did the same thing. Thank you both for your generosity.
  • Jimbo18
    Jimbo18 Posts: 2,351
    Rectifier? Damn near killed 'em.
    msg wrote: »
    I talk shop (glycoprotein characterization and biotechnology) at parties -- so, yeah, not often the center of attention. Remember the first scene of the movie Animal House, at the snooty frat? ;)
    hochpt21 wrote: »
    sorry, I missed that. FWIW, and apropos of nothing, I use a 5Z4 in my JE Labs "Simple 2A3" amp.
    With Ken being ban happy w/little to no warning, I'm afraid I minded my "p's" and "q's".
    Sad but true.
  • "And I will strike down upon thee with great vengeance and furious anger those who attempt to poison and destroy My brothers."
    That must've been written about those using mercury vapor rectifiers ;)
    Ok Jules,,, now try a beverage to wash down that tasty burger!
  • “Hamburgers: the cornerstone of any nutritious breakfast.”
  • vmaxer
    vmaxer Posts: 5,121
    Big Kahuna burger.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Kens on a roll today....and that is a royal burger my friend
