RT2000P
Hi! My tweeter and mid speaker quit working. Subs work. Is it a blown speaker? How difficult is it to repair? Any special tools or tips. I'm good at destroying stuff! Not so much on finding it lol! Thanks!
Answers
  • Hello,
    Welcome to Polk's forum. It is important that the upper and lower set of binding posts are linked. If the binding post jumper plates are not making contact and you have your speaker wire connected to the lower set of binding posts the woofer will work but not the tweeter and driver. If they are connected then you'll need to replace the tweeter and mid range driver. On Monday telephone Polk's parts department at: 1-800-377-7655 select option 2 for parts.
    Regards, Ken
    tonyb Posts: 33,068
    Personally I find it odd the tweeter and mids stopped working at the same time. If you have the rear plates connecting the top and bottom posts, then this tells me you may have fried something in the crossover for both to stop working at the same time. Best take a look see, anything burnt or blackened on the board before you start replacing drivers.
