Sub sounds like there is a bb in it. SB5000 soundbar
Droid
I have a SB5000 soundbar and the sub started making a rattling noise. With the power off I removed the 4 screws holding the speaker in the sub box. When I shake the speaker it sounds like a bb is loose inside. Actually to me it sounds like a blob of solder is in the speaker.
I don't know if it's under warranty. It was a gift.
Model SB5000 IHT Subwoofer
Serial AM1502A5490
Lot 3073143
We have been using it for less than a year. I have a teenage son, so my first guess is the idiot blew the speaker when I wasn't at home.
Can I buy a replacement speaker? Or would someone be able to tell me if it is covered by warranty or if there was a bad production run on that lot number?
I absolutely love this sound bar! I would like to fix it.
Serial AM1502A5490
Lot 3073143
Hello,
Welcome to Polk's forum. Probably the best way to determine the status of your warranty would be through Polk's CS department available at: 1-800-377-7655 select option 1. It would be helpful if you had the unit's serial number and place and date of purchase handy when you call. I believe they have weekend hours from 10:00am until 6:00pm eastern time.
Regards, Ken
