Vinyl Versus CD SDA Soundstage
Any reason why vinyl would have a "wider" SDA soundstage than a CD?
  • afishkind
    afishkind Posts: 15
    edited January 2017
    I'm not a physicist or audio engineer so it just perplexes me that all my CDs have a narrower soundstage compared to vinyl. I don't mind it at all ... just curious if there's some physics and math behind this effect ... or whether I'm crazy and nobody else observes this. Obviously there are many potential confounding variables. My son likes it better because he feels many albums have too wide an SDA soundstage on vinyl.
  • MrBuhl
    MrBuhl Posts: 2,419
    Does seem strange that ALL of your CD catalog is narrower, that should not be the case, I agree with Dskip, seems like you have a mismatch in quality somewhere in the chain between the two.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    F1nut Posts: 52,032
    What CD player are you using?
  • Schurkey
    Schurkey Posts: 2,122
    Am I wrong? SDA soundstage is entirely dependent on the difference between R and L. More difference = wider SDA soundstage.
    Given the limitations on stereo separation with vinyl, I'd have expected the CD to have wider SDA soundstage.
  • afishkind
    afishkind Posts: 15
    edited January 2017
    Using an NAD CD
    https://www.crutchfield.com/p_745C516BEE/NAD-C-516BEE.html
    I'm going to try a different preamp etc and see what happens.
    F1nut Posts: 52,032
    Ok, I've no experience with that player.
  • Nightfall
    Nightfall Posts: 10,083
    It's not just you. I find my vinyl setup to have a wider soundstage than digital/CD too and that's with the Oppo player on MIT cable and my turntable on stock Yamaha cabling.
    afterburnt wrote: »
    Village Idiot of Club Polk
    nooshinjohn Posts: 26,005
    I have yet to hear something that approaches my table, but then again, it is my one toy worthy of being in DK's or Joey's setup. I would go as far as saying DK would keep his vinyl rig if he heard this one...
  • voltz
    voltz Posts: 5,384
    I have many SACD's that I also have in Vinyl, I have started both at almost the same time/point and then using my remote switched sources and the Vinyl sound warmer & richer then the SACD's. which sounded maybe a tab bit brighter, but not sure they sounded wider just better by a smudged or tiny bit but to close to call a winner as I enjoy them both!
    I pulled out my MoFi Brothers in Arms and just did the side by side with my SACD copy of the same... they sound like two very different recordings, with the MoFi carrying far more weight in the bottoms end as well as soundstage.
    F1nut Posts: 52,032
    I'm not surprised as you're still using that Pioneer.
    F1nut Posts: 52,032
    My Japanese SHM-SACD copy of BIA blows away the Mofi copy, which blows away the original SACD release and not a single tick or pop to destroy the experience.
    The Pioneer has a decent reputation, but yes, I agree that could be a weak link, given the rest of the gear in the chain. As far as snap,crackle and pop go, those artifacts are few and far between, and only detectable between tracks on pretty dirty discs.
  • That seems to be the way MOFI masters there product in general...
    pitdogg2 Posts: 27,376
    you still rocking the Pioneer PD-D9
    I ended up with one darn nice player IMHO beat all my Denon's and Sony's
  • K_M
    K_M Posts: 1,631
    http://www.recordingmag.com/resources/resourceDetail/114.html
    This explains a lot. About half way down the article.
    Lot of stuff going on to make the sound on vinyl.
    Not even close to straight forward. No wonder it sounds differnt.
  • DSkip wrote: »
    It could be that your vinyl rig is just better than your digital. Cabling could work better, component ability could be better... something is better there. I know many feel vinyl is king but I don't feel that way. I think both are exceptional, though it does tend to be a little easier to set up a good sounding vinyl rig, especially when vintage records sell for pennies.
    Sell for pennies ? Not since the hipsters got on board the vinyl train. A decent used record is 15 buck and up. CDs are really cheap.
    As far as the comparison with the soundstage between the two, my wife who doesn't care anything about equipment , commented that the Polks sounded like they were made for vinyl. To my ears, much more involving.
    As I recall, one of the reasons SDA's were discontinued was they were not digital ready.
  • I only find well worn records at Goodwill or stuff I have no interest in. Some of the old Telarc CDs sound pretty good.
    F1nut Posts: 52,032
    K_M wrote: »
    An excellent article.
    "With each generation, some small amount of detail is lost, and as a result the final pressings never seem to sound quite as good as the original acetate."
    So, what ends up on the LP isn't as good as what ends up on a CD.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Too many new pressings sound just like the cd anyway, so what's the point? Especially when new black discs are selling for 30-40 bucks. And I can get the cd for 5 bucks new. I enjoy all medias, and I like the vinyl experience. But my shanling smokes my anolog and digital. Tubes baby! Get some tubes in that signal path!
    2 channel:
    Theater:
  • Schurkey
    I don't think it's that simple. There's plenty of tomfoolery going on in the processing before the CD bits are finalized. Vinyl requires playing games with bass and loudness to make the best use of the three-dimensional "real estate" allowed on a production vinyl disc. The sound is modified to make the groove playable by an enormous variety of "record players" including "bottom-feeder junk", "High-End" and everything in-between. By comparison, the CD medium has considerably less limitation on channel separation and dynamic range, less limitation on deep bass, but a hard upper limit on treble (the only place vinyl exceeds CD). The issue for CD is largely "marketing", by which I mean excess compression. The CD is less "inherently" compromised than vinyl, but it's as-much or more commercially compromised. The content is altered so it "sounds good" on deeply-flawed ("mainstream", "boom box", "rack system") equipment, to people without musical training or an appreciation for nuance. One could argue that all the commercial compromises inflicted on CDs should also be present on vinyl, and for the same reasons. In the context of this thread, only channel separation matters.
    If you've got wider soundstage with SDA speakers when playing vinyl, I'd be asking myself why the CD rig or source discs (apparently) have less separation between L and R. This is about stereo separation, (the difference between the L and R channels at any instant in time) not analog vs. digital, not vinyl vs. polycarbonate, not grooves vs. pits. The theoretical advantage goes to the CD. If that's not what you're hearing, 1) there's something wrong with your playback system that is blending L and R on the digital side, 2) there's something wrong with your system that's exaggerating L/R separation on the phono side; or 3) the theoretical advantage in channel separation that CDs have is not being utilized when the CDs are mastered. There were numerous discussions about CDs being mastered "Hot" (excess treble) when the medium was new. There is considerable proof that dynamic range has been compromised on CDs for years--the so-called "Loudness Wars". It would be no surprise to discover that CD masters have deliberately-blended the two channels to some kind of "glorified mono" rather than the real "stereo" that they're capable of.
    If the problem is what's recorded on the discs, everyone who compares CD to vinyl is going to experience the same thing. I don't think that's happening, but I've got no personal experience to back that up.
    First Guess: You can verify the performance of the CD side of the system with any one of multitudes of "CD Test Discs". If you have good channel separation on the test discs, the problem is not in the CD side of the playback stream unless it's in the music CDs as discussed above. Conversely, if the channel separation is poor on the test disc, the CD playback system is flawed.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    afishkind wrote: »
    If your vinyl consistently has a wider sound stage than your digital, your vinyl equipment has better resolution than your digital.
    I've done lots of comparisons of multiple digital and multiple vinyl versions of the same album and the results were usually mixed based on the care that went into the mastering and manufacturing of the respective digital or vinyl disc.
    I am currently transferring my vinyl collection to DSD digital. I have been frequently struck by how much better some of my 20 to 30 year old "ordinary" 33-1/3 rpm albums sound compared to expensive "audiophile" albums pressed on "premium" heavy weight vinyl after being carefully "remastered" by revered record producers.
    The biggest shock has been that, without exception, the DSD transfers of my vinyl records sound better than the records.
    What qualifies a loudspeaker for being "digital ready"?
    At this point, I doubt that I would keep a vinyl rig in my 2 channel rig no matter how good it sounded. I no longer want to deal with the inconveniences.
    I gave some serious consideration to selling my vinyl rig, but I realized I need to keep it for the occasional record I might buy and need to transfer to digital.
    I did sell my Pass Labs XP-25 phono preamplifier after I had transferred all my audiophile and 45 rpm records to DSD.
    edited January 2017
    Wish I would have known you were selling that one... if I could have found the dang quote from Mr Polk, I believe he said something about the digital format and SDA. Could be it was mentioned in passing as part of his commentary on the changing nature of the business as a whole. Too much going on in life these days for me to keep up. :D
  • daddyjt
    daddyjt Posts: 3,147
    I had the same experience with the Japanese release of Aja on SACD - absolutely buries the vinyl. No pops or ticks, and I can navigate the album from the couch with my remote:-)
    ― Aleksandr Solzhenitsyn
  • Nightfall
    Imagine if someone made a source that could be manipulated with just your thoughts. Then you wouldn't even have to move. o:)
    afterburnt wrote: »
  • DarqueKnight
    I recall Matthew Polk saying the market was going to smaller (and cheaper) speakers and that was the main determinant behind discontinuing SDAs.
    F1nut Posts: 52,032
    Polk had the all digital copy of BIA as one of the recommended demo CD's in their SDA literature.
