LSiM 702 F/X or LSim 703 for rear speakers
first capital
in Speakers
I purchased the LSiM 707 fronts, LSiM 706 center and LSiM 702 F/X rears but my wife does not think she will like the look of the LSiM 702 F/X speakers on the wall. It seems to her that she likes the look of the LSiM 703 book shelf speakers n stands for the rear! Would I be giving up much to go with the LSiM 703's?
The 702s will disappear better for surround effects if they are mounted on the wall well above seated ear level and the 703s will be more direct. I use 703s as surrounds because wall mounted 702s are not an option for me because of windows. If the 703s are used as surrounds it's best to get them as high as safely possible on stands. Mine face straight forward from the rear in an equal plane with the front speakers. I am happy with the setup the way I have it.
I use the 45" tall version of these as stands:
https://www.amazon.com/Ultimate-Support-Professional-Non-marring-Decoupling/dp/B005QM6UE2/ref=sr_1_35?ie=UTF8&qid=1483385642&sr=8-35-spons&keywords=large+speaker+monitor+stands&psc=1
I have the 702's as rear surrounds. (just got them)
They are mounted high and I love them... -
I have the same setup. 703's with the exact same stands. Great minds think alike!2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
first capital wrote: »It seems to her that she likes the look of the LSiM 703 book shelf speakers n stands for the rear! Would I be giving up much to go with the LSiM 703's?
Just your nuts....
I keed....
"Just your nuts...."
35 years of wedded bliss will do that to you!
