FS: Nakamichi TA-2A Receiver (Needs Work)
markmarc
markmarc Posts: 2,309
edited November 2016 in For Sale (FS) Classifieds
A third receiver from the stereo closet. The Nakamichi TA-2A needs a solder jockey as it has no output unfortunately. The volume knob and balance ring need replacing as the original cracked at the mounting point (originals in box). The mechanism itself is fine. All other knobs, buttons and lights work. The case is in excellent shape. Working units fetch north of $200 on eBay because the STASIS circuit design by by the legendary Nelson Pass. $50 plus shipping, payment via PayPal. Box dimensions and shipping weight: 24x20x8, weight 25lbs, shipping from 97123.
Description
The Nakamichi TA-2 is a high definition tuner amplifier which brings utterly pure sound within easy reach.
In the power section, the extraordinary STASIS circuit topology combined with high current capability results in ample output power and excellent speaker drive characteristics.
The pre-amplifier features Nakamichi's innovative isolated ground principle for complete freedom from interference between various circuit stages.
Specifications
Tuning range: FM, MW
Power output: 50 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.1%
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 78dB (MM), 100dB (line)
Output: 150mV (line), 1V (Pre out)
Speaker load impedance: 4Ω (minimum)
Dimensions: 430 x 100 x 370mm
Weight: 8.6kg
Former Staff Member TONEAudio
2 Ch. System
  • classic carl
    classic carl Posts: 661
    I bought a working one of these on another forum for my son. He's using it in his bedroom system at his place. When it arrived here, the volume knob was broken where yours is, right where the internal stem attaches to the inside of the knob. I was able to repair it with superglue. It works fine now.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
