Binding posts and metal conductivity?
  • vmaxer
    vmaxer Posts: 5,124
    Well, this got lively.
    See what you started. >:)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • motorhead43026
    And the boots you lick will stomp you too.
  • codycatalist
    Pass that shizz
    mhardy6647 Posts: 35,562
    edited November 2016
    I, in all seriousness, am out of my depth* when it comes to metallurgy.
    _______________
    * "Depth" -- Skin effect, plating... heh-heh-heh :blush:
  • DarqueKnight
    Here is the response I received from Furutech::
    My question:
    "Your website states:
    "The FP-803 features Alpha phosphor bronze conductors for minimal impedance and nonresonant matte black finished eutectic copper alloy housings."
    Since phosphor bronze is 4.7 times less conductive than gold and 6.7 times less conductive than copper, I understand that conductivity of the bronze can be increased to equal that of copper or gold simply by increasing the size of the bronze. But then I would think there would be a problem with the larger amount of bronze having a detrimental effect on the sound quality of the binding post because most of the signal would go through the bronze base metal rather than the thin gold plating. How did Furutech address the issue of using a large amount of bronze without detrimental sonic effects?"
    Furutech's response:
    "Thank you for your interest in Furutech products.
    Furutech tested numerous samples of phosphor bronze with varying percentages of tin and phosphor before deciding on the right mix for sound reproduction and use in their products. The phosphor bronze also under goes deep cryo treatment for improved conductivity.
    Phosphor bronze is only used in the FP-803 post - all other Furutech posts are OFC grade copper or OCC wire. Please follow this link for other options: http://www.furutech.com/products/component-parts/binding-posts/
    Hope that helps.
    Kind regards,
    Furutech Co., Ltd.
    Tokyo"
    F1nut Posts: 52,406
    Ray, thanks for saving me the effort to contact Furutech. It seems they no longer offer the other models that used phosphor bronze, such as the 806 and 816. However, those models are still available from resellers and I was looking at the 806. Since they now only use it in their entry posts I have to think they figured out it wasn't the best idea after all.
  • DarqueKnight
    xcapri79 wrote: »
    I'm correct on all counts, no need to assume.
    Please read the response from Furutech and explain how you can be correct on any counts when:
    1. You don't know the conductivity of the phosphor bronze base metal compared to the gold plating. Furutech said they tried different formulations of phosphor bronze. These various formulations of phosphor bronze have different conductivities and sonic signatures.
    2. You don't know the type and thickness of the gold plating and the thickness of the phosphor bronze base metal.
    3. Since you don't know the relative conductivities and masses of the base metal and plating, you can't definitely say that most of the current goes through the base metal.
    4. You don't know what other metals are used in the construction. For example, most gold plated binding posts are gold over brass, but the brass is first plated with nickel because gold does not adhere to brass very well. However, you seldom, if ever, see the nickel plating mentioned in marketing materials...only the gold. In the case of gold plated brass with nickel between the brass and gold, nickel is 21% less conductive than brass, so there is a further difference in conductivity between the gold contact surface and the substrate. Phosphor bronze is usually plated with a nickel substrate, but Furutech didn't specifically say. However, some type of substrate had to be used between the gold and the bronze.
    If you have metallurgical and electrical performance data from Furutech pertaining to their phosphor bronze binding posts, please present it. Otherwise, you are just speculating.
  • gp4jesus
    gp4jesus Posts: 2,025
    How about this BP base material comparison, again because some are discussing conductivity:
    On the left, brass; on the right, phosphorus bronze. Left plug design provides more surface area, tighter fit, and plastic sleeves versus metal.
    *all connected w/Premiere ICs
    EndersShadow Posts: 17,763
    This entire conversation and ALL the comments offend me.
    Can we setup a Polk Audio "safe zone" so I can post in that section and cry and play with playdoh.
    Sorry, dont really have anything meaningful to add besides "I agree with Ray" :smile:
    this should send all y'all scampering, whimpering & sobbing, to your safe zones.
    30055252362_7bafbc89ba_b.jpgDSC_6122 by Mark Hardy, on Flickr
    EDIT: That's a very vintage JBL 275 1" compression driver mounted to an H5040 (right angle) "Metregon"-style treble horn, by the way.
  • K_M
    K_M Posts: 1,631
    O.C.D. and caffeine do not make a good match.
    Think we can all agree on that.... :)
  • Nightfall
    Nightfall Posts: 10,083
    Noooooo! I hope those 5 cent spades and alligator clips are at least cryo treated, tell me they're at least cryo treated!?
    afterburnt wrote: »
    Village Idiot of Club Polk
    I put the wires in the ol' Kelvinator for a while before hookin' 'em up ;)
  • daddyjt
    daddyjt Posts: 3,266
    There... I ALMOST posted it with a straight face... :D
    c38.jpg 25.3K
    ― Aleksandr Solzhenitsyn
  • lightman1
    lightman1 Posts: 10,803
    You're fired, Hardy.....twice.
