PSW300 help
NWebber
Hi,
I'm servicing this sub in which the amplifier has failed (and cooked the woofer, or the other way around...)
Beside the shorted dual output/power transistor I found also a 1w(?) resistor that is burned and reads open.
Its color stripes are completely darkened so I can't identify the value. It is labeled R16 on the PCB.
I would be grateful for any help identifying this R16.
Thank you,
N.Webber
Thank you,
N.Webber
Hello,
Welcome to Polk's forum. Polk's CS department should be able to provide a schematic, telephone 1-800-377-7655 select option 1.
Regards, Ken
