Why is it so hard to get a schematic PSW202?????????????
It seems there is a common issue for the Polk Audio Sub PSW202. Blowing fuses. In the articles I have read it seems the common issues are the large electrolytic caps. Right beside the the Large caps there is a smaller cap on my unit that is blown. C24. Can anyone give me the value of this cap? Does anyone have any theories to why it blew? I can not find any schematics on the web. Also was wondering why you can't find them. Thanks for any help.
    pitdogg2 Posts: 27,549
    edited November 2016
    Have you called Polk Customer Service?
    9AM-5:30PM EST Mon-Fri
    1.800.377.POLK (7655) Option 1
    FAX: (410) 764-5470
    polkcs@polkaudio.com
    International: +1.410.358.3600
  • drob
    drob Posts: 2
    I called them and they were kind enough to send a schematic. I replaced the the large caps, and the IC. Now when I plug it in it burns resistor R12. Any ideas?
    F1nut Posts: 52,144
    Have you considered having a professional repair shop take a look?
    I dunno man, seems to me that's a sign to buy a new one, or better used one. For what a shop would charge to fix it, add a couple bucks and grab a 505 sub.
