Looking for a power strip
Easy Runnin
I have an amp, preamp, tuner, CD player and turntable in a cabinet, all plugged into a power strip. I’m thinking about adding a second amp, a turntable lamp and a fan to help keep things cool. I think I want something easily accessible with a single switch to turn everything on. I see a few Furman M-8’s on CL. Would this be a good choice? It seems more geared to pro audio. If this isn’t good, what would you recommend? Can I get anything decent in the $100 range?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Trust me....I'm an electrician.....
only an electrician is capable of making that big of a mess. Guessing 2 channel with maybe 3 components.
Panamax M8-AV Home Theater Power Management (Grey) https://www.amazon.com/dp/B0030TWBP0/ref=cm_sw_r_cp_tai_fKa-xbW2CM3EV
This is in your price range. -
Lightman knows how to load a circuit!
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Thanks for the replies. I found a used Panamax 4300. That should hold me over for awhile.HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
BR - Yamaha CR800/Polk monitor 5 -
i was going to say these are well reviewed.
https://www.amazon.com/Wiremold-L10320-Power-Strip-outlets/dp/B00DWIL16O/ref=sr_1_1?ie=UTF8&qid=1476031307&sr=8-1&keywords=wiremold+l10320Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
