Clarity ESA 250vdc vs 630vdc?
gwg_97
I can get the 12uf 630vdc for 40 percent off. The 12uf 250vdc is out of stock. Is there a difference? Thx!
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
Best Answers
Good to know. I assume both will work and there will be no discernible difference in sound quality. Correct?
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded -
Correct but you have better have some room they are BIG.Good to know. I assume both will work and there will be no discernible difference in sound quality. Correct?
Answers
Yep one will be much bigger. Guess which one is larger?
They're yuuge!Home Theater/2 Channel:
dhsspeakerservice.com/ -
Confirm thier size before ordering. I ordered SA 600v once and the 50 caps were the size of a coffee can in diameter and about 4/5 inches tall. So word to the wise. Returned them and got the ESA'S 250v and was very pleased!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Thanks guys, much appreciated. I think I'll stick with the small ones.
nice Caps.....
