Any help with wood antique chair repair would be appreciated.
Dabutcher
We bought this chair for $100 a few months ago. My wife really likes it a lot. I sat in it today and the bottom of the back and the arm all three broke off? Any ideas on how to fix it ? Thanks. D
From what I can see, the left rear post (as you sit) was broken off and poorly repaired, hence the root cause of your problem today.
Edit: looks like the right side had some work as well.
The best advice I can give is take it to a professional and be prepared to pay a lot for a proper repair. -
I assure you that a proper repair will exceed the purchase price by a large amount.
She really ,really likes the chair. I was thinking I could saw off the stubs and find some big wood dowels. And drill holes in each side and wood glue both ends. Thanks for both your suggestions. Peace. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Schram rockers
probably best to try to look for another2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I've done repairs like that. Takes a lot of patience, and perfect alignment to drill out the spindles. A qualified restorer would probable have a specialty wood lathe designed for that purpose. Similar to how a gun barrel is bored and rifled.She really ,really likes the chair. I was thinking I could saw off the stubs and find some big wood dowels. And drill holes in each side and wood glue both ends. Thanks for both your suggestions. Peace. D
Home Theater/2 Channel:
dhsspeakerservice.com/ -
The good news is it looks like the breaks are in inconspicuous places, the view of which is obscured by the architecture of the chair from most positions. This may make an amateur repair more tolerable from a "beauty" standpoint. The problem is it looks like there is significant weight/pressure on the broken areas, hence less stable repairs are likely to re-break easily.When freedom is outlawed, only outlaws are free...
