Receiver Upgrade Evaluation
Early B.
Early B. Posts: 7,900
edited March 2004 in Electronics
I've got a few hundred extra bucks and I'm trying to determine whether or not I should upgrade my receiver. I currently have a Denon 1803 that I like a lot (80 wpc). I was looking at the Yamaha RX-V1400 or the new Denon 3805. I'd rather stay with Denon, but the 3805 is a couple hundred bucks more than the Yamaha. I don't want to spend any more than $650.
For those of you who have recently upgraded, is it worth upgrading??? (Please indicate what you upgraded from). I am mainly interested in acquiring better sound quality. Not concerned about auto calibration and other such gimmicks, but PLIIx sounds interesting.
I'm about 60/40 movies to music and never play either one loudly. My room is 13' by 20' with 8 ft. ceilings. I have a 6 channel setup (it's all my room will allow) and play music only in 2 channel mode. I rarely play the TV through the HT setup. Is pursuing PLIIx worth the upgrade in my case?
My setup:
Fronts: Rti70's
Rear: 38's
Surrounds: Fxi30's
Sub: Hsu VTF-2
DVD/CD player: Cambridge Audio 540D (awesome!!!)
Thanks for your input.
P.S. -- one more question: should I save more pennies and invest in an upgradable receiver? Are they worth the extra bucks just for that feature?
"God grooves with tubes."
Post edited by Early B. on
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2004
    I don't think you're going to notice much change until you make the break to a seperate power amp. If you like the features of a receiver, go the receiver w/preamp outs route.
    I just don't think you'll be satisfied with the money spent if you continue to upgrade receivers. Time to move to the next level.
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2004
    Here, here!
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • amulford
    amulford Posts: 5,020
    edited March 2004
    I have to agree, unless you want to spend alot more than $ 650. You could get a decent set of amps for that and check it out. Steve is right, IMO.
  • fireshoes
    fireshoes Posts: 3,167
    edited March 2004
    Try not to dismiss the room eq stuff as voodoo. It made a big difference on my system.
  • pjdami
    pjdami Posts: 1,894
    edited March 2004
    Both the Yamaha and the Denon are nice receivers. At that price point it comes down to personal preference / features.
    The next level up, and this is just my personal opinion based on what I experienced, would be a NAD T752. It can be had for under $650 refurbished and has high current capability if you ever decide to get 4 ohm speakers like the LSi in the future.
    http://www.yawaonline.com/yawaonline/nadt7re.html
  • mantis
    mantis Posts: 17,557
    edited March 2004
    No it's a huge difference.The power supply in the 3805 is much greater then the 1800 series.It has alot more control over your bass.
    The 3805 is so much better then the Yamaha.Spend the extra bucks dude you'll be happy you did.
    Personally I think the Yamaha has a bright hissy terrible sound but everyone gets caught up in it's new features.Yamaha is new to the all out feature battle.Denon has been smoking them for years.No difference here other then Yamaha released there new products first.
    Denon is a solid company and has my full support with the speakers you own.
    I feel there is no better match for the rt series.
    Dan
  • fireshoes
    edited March 2004
    Hey mantis, have you installed any 3805's yet? It seems like a few people have had problems with their remotes causing the receiver display to dim. Just curious if you had ran into that yet.
  • mantis
    edited March 2004
    We only got in a few and they where all sold prior.We are blowing out the avr3803's first.
    The new remote I haven't run into that problem or heard of it untill now.I can ask the other installers and see if any of them had any problems.
    I'll let you know,
    Dan
    Dan
  • Early B.
    edited March 2004
    OK, I'm willing to try a separate amp. Maybe get a used one on ebay or audiogon. Perhaps a Parasound or Acurus or Adcom. But first, I have three questions --
    1. Should I start with a 2 channel amp to power the front speakers, a 3 channel amp to power the fronts and the center, or two 3 channel amps for my 6.1 setup?
    2. Can I use my Denon 1803 as a preamp?
    3. For my setup and listening preferences, should I try to get the most power for my budget or does it really matter?
    Thanks.
  • pjdami
    pjdami Posts: 1,894
    edited March 2004
    Early, if you add an amp to your fronts more than likely you will have a mismatch of power due to different gains on the amp input vs. the receiver amps. This might cause problems with the HT experience. You would have to get an amp with a variable input gain and then the timbre might not match as well.
    Since you say that you don't listen very loud, I question if an amp is going to do you any good. You can use the Denon 1803 as a preamp but if you are after a different sound quality much of the sonic signature that you have with that preamp will remain. You may notice very little difference at all (not listening loud).
    To change the sonic signature significantly you have to change out the preamp. Since you like Denon, the 3805 is a solid choice. The NAD will sound different as well and so will the Yamaha. This is a very personal choice here and that is what is difficult; getting demos on all this gear and getting to know it in your home.
    I think you have some good recommendations above; what you decide is really up to what you like and what you are after in terms of sound quality. Brighter ... darker... neutral ... etc.
  • dragon1952
    dragon1952 Posts: 4,907
    edited March 2004
    I don't think the 1803 has pre-outs for an external amp.
  • amulford
    edited March 2004
    Your right it doesn't have pre outs. I have an 1802 that has pre outs for the mains and center, I was **** u Me ing the 1803 would also.
    I think the direction Mantis stated would be the way to go.
    If you are really set on ugrading, the 3805 is a nice piece of equipment. Save a few more shekels and treat yourself;)
    Just my .02.
