Oil filter help question
K_M
K_M Posts: 1,632
edited June 2016 in The Clubhouse
Need to buy some oil filters for a few of our cars. Previously had a relative do a lot of our car work, but he is no longer with us.
My question, can anyone recommend a decent oil filter, that is not a high priced one, nor a junk one, but something decent at a mid-price level?
Preferably something that can be had at Walmart or Advance auto.
Nothing esoteric, just good and reasonable priced.
I have seen bashing of a few brands, but also much praise of same brand by other people.
So not sure what is truly good or bad.
Having neighbor boy, help us with this, but he asked what kind to buy and we drew a blank!
We are against "quick lube" places and dealers....!
  • motorhead43026
    motorhead43026 Posts: 4,012
    edited June 2016
    Wix oil filters, Napa gold are made by Wix. I run this brand on all my classic cars including my daily drivers, these cost 5-6 bucks. Find a Napa Auto Parts store and purchase there.
    – Kevin Alfred Strom
    tonyb Posts: 33,072
    Personally, I don't see much difference in brands of oil filters, unless you get into the more expensive stuff but those are probably more suited for higher flow engines. Some brands though have a tighter fit and are more inline with what is stock for your vehicle.....and won't leak.
    Most domestic cars/trucks can use any crossed brand and I don't see a problem using those quick change places as most use the stock brands anyway your going to buy anywhere else. Plus they can check other things that you won't normally due yourself.
    That said, I've taken both my cars to a Valvoline quick change joint with no problems and always use a synthetic oil which is obviously more expensive. Change every 5k miles.
  • Legender
    Legender Posts: 478
    edited June 2016
    From one of my favorite sites : Bob is the oil guy. Any of these would probably be fine:smile: Top rated filters from 2013 : 1 Pure One
    2 Motorcraft
    3 Puro Classic
    4 Wix
    5 Mobil 1
    6 AC Delco
    7 Napa Gold
    8 Toyota OEM
    9 Bosch D+
    10 K&N
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
    pitdogg2 Posts: 27,055
    stay away from FRAM they are just JUNK cardboard. Any of the purolator's, O'reilly's also carry Wix. If you one a GM AC-Delco if you on a Ford Motorcraft. As said above some sites have dissected oil filters and found some interesting stuff used to make them I would not want on my vehicle.
    these are the big three that are really darn good.
  • DaveHo
    DaveHo Posts: 3,583
    I like Wix and since my cars are all GM brand, I'll use ACDelco as well. As was said, stay away from Fram. Usually I'll order a bunch for my 3 cars from RockAuto.com every year or so. Works out way cheaper than buying locally.
  • deucekazoo
    deucekazoo Posts: 146
    I use WIX in most of my cars but on few I will use OEM filters. They are not that much more from the dealership and they are made for the car. Now I will mention something that might worry you depending on the car you have or I will be told I am full of it. So depending on the car manufacturer or engine the aftermarket filters are not recommended. This all has to do with the bypass pressure on the filter. Most aftermarket filters are set to a certain pressure so once the filter gets clogged then it will open up so it does not starve the engine of oil. Some cars like Subaru run higher oil pressure in their engine and this activates that bypass in the filter even when its not clogged. So the filter is not filtering your oil. So on my Subaru's I run OEM filters.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • muncybob
    muncybob Posts: 3,240
    Been using Wix and Purolator over the years and on some fairly high mileage cars...never had a problem. For oil, any vehicle with 50k or less miles on it will get switched to Mobile 1 oil, otherwise I go with a blend of synth/dino oil. Our 97 Cavalier used Mobile 1 from the 1st oil change...body and frame rotted out but engine was still strong with no oil consumption at well over 200k miles.
    Yep, my name really is Bob.
    heiney9 Posts: 25,437
    edited June 2016
    With all my Volkswagen's over the years and my current one. I use OEM, Mann or Bosch filters from a reputable parts supplier. Other's aren't recommended by the manufacturer or my mechanic of 30 years.
    From a reputable parts supplier the OEM filters cost about 25% more than off the shelf brands from the local auto parts store. I don't buy from the dealer unless absolutely necessary as their mark-ups are very high.
    Also have only run synthetic oil in all my cars.
    edited June 2016
    Also, on my current GTi, the oil filter sits on top of the engine, upside down. Super easy to change and access the filter. It has a check valve in it to keep the oil from spilling out when you pull the filter off (since it's upside down). Not sure in my case if the aftermarket, off the shelf ones have the check valve.
    You can see the oil filter (black) right below, next to, the orange dip stick.
  • befuddle
    befuddle Posts: 126
    Thanks K_M for starting this thread. As I've always just used Fram thinking that they were a well respected brand. And although I've never had any problems using them Never had any leaks and always drained my filter separately to inspect for possible wear damage,But due to the respect the brand has here I'm definitely going to switch! Thanks for the heads up guys!
  • JPete
    JPete Posts: 295
    There are only a handful of oil filter manufacturers. Most of it is just different brandings, like everything else. All about marketing and margins. Best thing to do, if you are actually concerned about the type of oil filter you use, is go to Bob is the Oil Guy website and do some searches on your vehicle. More information than you'll ever want to know about there.
    That said... Purolator manufactures these brands - Bosch, Motorcraft, PowerFlo, ProLine, Purolator Premium Plus, Purolator Pure One, Quaker State.
    Wix manufactures these - Carquest, NAPA, WIX
    I use NAPA branded WIX filters in most of the cars and Amsoil filters in my daily driver. Some Amsoil filters are/were made by WIX, but the synthetic nanofiber ones I've heard are made by Donaldson.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • K_M
    K_M Posts: 1,632
    edited June 2016
    I read a lot about stuff saying Fram is not good at all, but I then also found a lot saying they are unjustly bashed. That some filter they had over 10 years ago was bad, and they are not bad anymore. Who knows.
    It is kinda like how Bose gets bashed.
    I would think, if they are as bad as many are saying, how would they even stay in business though...lol?
    Oh well went with some Purlotor One for now. Will maybe try another brand soon, when 2 other cars need done.
    Thanks for all the ideas and thoughts....!
  • Polkie2009
    Polkie2009 Posts: 3,834
    JPete wrote: »
    Thanks Pete for the solid info here. I was going to add years_ ago , the Amsoil filters were made by Hastings.
  • Dabutcher
    Dabutcher Posts: 2,606
    I own two Toyotas. Their OEM filters are buy four get one free at my dealer. I pay $43.00 for a box of ten filters. They have cellophane over lubed oring. No issues ever. Good luck. D
  • lightman1
    lightman1 Posts: 10,796
    Sure...but which filter sounds better?
  • lightman1
    Sold! I trust your judgment, Ken. Thanks for the input.
  • JPete
    JPete Posts: 295
    edited June 2016
    I've noticed that using Amsoil filters in my car creates a much more spatial presentation of exhaust sound. With the K&N, it lessens the soundstage, but the detail is much better.
  • muncybob
    I will offer a burn in service for your oil filter. Double blind tests have confirmed you will need to change them more often though.
  • I have used Wix filters, both oil and fuel in my truck since I bought it new in 1997. Never had a problem.
  • exalted512
    exalted512 Posts: 10,735
    Don't really have much to add that hasn't been said already except for I've started getting all my oil and filters off of amazon. Prices are usually tax free and are as cheap as Wal-Mart (Which is the cheapest oil around).
    -Cody
    billbillw Posts: 7,556
    edited June 2016
    Sometimes you need to do a little research at the online forums for your car.
    My current Subaru Legacy GT (same engine as WRX) has a higher than average oil pressure so the check valves in most filters will not hold (resulting in blow by...ie: unfiltered oil passing through). So the only recommended filters are the OEM or as it turns out, a specific Mazda filter that was made for the RX-8! Luckily Fred Bean orders them from Mazda and sells them in packs of 6. That reminds me...I just used my last one a few weeks ago. Time to order more.
    EDIT: Then I find that Fred Bean closed their internet sales dept!! Time to find a new source.
  • mikeyb128
    mikeyb128 Posts: 2,885
    I have worked in the auto industry going on 13 years. At our shop we always use OE (original equipment) or OEM (original equipment manufacturer) the cost difference between cheapie filters and the OE/OEM is maybe 6-7 more bucks. And in my opinion is not worth the risk. Ive seen everything from leaking filters, degradation of the filter material to the point of crumbling, low oil pressure, and coking/sludging. So for our customers it's always genuine filters, or at least the manufacturer that makes them. But hey, if you know your German cars you also might know they can be a little finicky.
    2 channel:
    Theater:
  • lightman1
    BMW 740iL......
    It hates everything. ... :s
    Yep, I wouldn't call my GTi finicky (maybe a little), but I use only OE filters. It just makes sense to me.
    heiney9 wrote: »
    try after market spark plug wires on the GTi Brock....yep they're not going to run your car. A good friend found out the hard way...
    In the last 4-5 yrs MOOG suspension parts are now made in china. MOOG states they send the good parts over to be "assembled" well we all know how badly china counterfeits stuff. I will no longer buy MOOG I will pay twice the price for Motorcraft parts for my Ford. A couple of years back i replace all ball-joints tie rod ends on my truck with MOOG I had 3 failures in the first year. NEVER AGAIN.
    edited July 2016
    No such thing as "after market" plug wires. Direct injection with coil packs on each spark plug which snap into a central loom. I still use the OEM coil packs.
    My old GTi VR6 had after market Magnecor's and they were simply fantastic and lasted forever.
    The **** of it is you need a special coil pack puller and a magnetic long extension socket to change plugs or coil packs.
  • mikeyb128
    Can't stress enough how important OE plugs and coil packs are for vw and Audi. I see this STI junk brand on them all the time and cost about 8$ less than OE.
    2 channel:
    Theater:
    heiney9 wrote: »
    yep same as my Ford truck coil over plug I also would not use any after market stuff.
    his still had wire not sure of the model of VW but it didn't like them none the less.
    mikeyb128 wrote: »
    Yep, it's not cheap but I just replaced the original Bosch plugs in my '09 GTi at 75,000 miles. For peace of mind I put new OE coil packs in too. The plugs were very worn, but she still ran well. It runs better with fresh, properly gapped plugs for sure.
    OE from an aftermarket supplier for (4) Bosch plugs and (4) Bosch coil packs was not cheap............$120 for coil packs and $55 for plugs.
    I have 78,000 miles now and next is the 80,000 mile service for the DSG gearbox. I'm having the dealer do it since it has a 100,000 warranty. I don't want them to say since it was serviced somewhere else they won't cover an issue if I should have one. I'll be relieved of about $500 for a fluid and filter change, OUCH! But I knew that going in.
    $35 per liter for tranny fluid and it take 6 liters = $210 + $45 filter + dealer labor
