The tube thread!
    heiney9 Posts: 25,553
    Faustin wrote: »
    Ok.I looked at the Hammond tube again in different light and angles with a magnifiying glass and I am pretty sure the top line is I63. The I is very smudged and the 6 is smudged a bit, making it look more like a C. It is a short plate and has a halo getter. From my research it would be the short plate with the 3 being a change code. The 2nd line of B5K1 would indicate Blackburn factory, 1965, November, 1st week. Sound correct?
    The Amperex 12au7's getter is attached by a rod to the mica.
    Also, I agree that the codes tell everything. It is interesting how hard it is sometimes to find the codes. I have looked at some tubes and been frustrated because I cannot find anything to go by. Then, later in the day or the next day I will check it out again and lo and behold I am in just the right light etc and there it is.
    Yes, since the change code is I63 then the year is 1965. If the change code was I66 then the year would be 1975 and the getter would be a solid disc with dimples.
    edited June 2016
    I have a 1956 ECC82 Amperex Holland long plate where there is no post. The D getter w/foil is angled and tacked to the plate post. Rare, probably no sound difference. My other 1956 and 57's and 58's all have the post.
  • voltz
    voltz Posts: 5,384
    Have you tried any Amperex 7062 USA? I got a set from Snow i use in my Dared Preamp and really like them.
    like theses
    http://www.tubemaze.info/amperex-7062-usa/
  • george daniel
    george daniel Posts: 12,096
    For my applications,,the Brimars just have the right amount of "sparkle",, especially in my old Belles Pre,,which was a kinda dark sounding pre ,,the Brimars were perfect
  • lightman1
    lightman1 Posts: 10,797
  • ken brydson
    ken brydson Posts: 9,048
    lightman1 wrote: »
    Tube nerds.
    They're fun at parties, lol...
  • mikeyb128
    mikeyb128 Posts: 2,885
    Mine do have the holes. And I found date codes! Not sure why I didn't see them before. 4H1/1571
    On all 4 tubes.
    2 channel:
    Theater:
    Yep, nice tubes for sure. That date code can appear anywhere on the tube, even vertically. Sometimes it's under the other markings on the tube. They are very easily rubbed off too.
  • Faustin
    Faustin Posts: 1,151
    Talking about the codes being anywhere, I have a re labelled tube that I think is a Mullard, where the code appears to be upside down. I could not figure out what was there and then when I turned it upside down I was able to make out some numbers etc. Still very hard to make things out but pretty sure things are upside down.
  • mikeyb128
    I have valvos with Mullard date codes upside down. Seems common for them.
    2 channel:
    Theater:
    I've seen that with some Mullard made tubes. Weird, but maybe it was Friday at closing time......lol
    Another fantastic tube to try (if you can find them). In fact this might be my new favorite. 1948-51 Tung Sol 12AX7 - black plate w/square getter (slightly bent on short post). Extremely rare, although I managed to pick up a quad within the past 6-9 months(1 tube at a time). I have been hunting them awhile.
    I could go on and on about these, they are superb but this link pretty much sums up how I feel as well.
    http://www.tubemaze.info/tung-sol-12ax7-black-plates/
    Clarity, transparency and soooooooo smoooooooth......not a hint of grain or harshness.
  • mikeyb128
    More tubes for me to try :) will keep my eye out. Wish I had the funds to buy everything.
    2 channel:
    Theater:
  • mikeyb128
    edited July 2016
    Anyone use conductive paste on tube pins? Like gold or silver? Found this stuff at work... g0dwtc4xf93o.jpeg
    2 channel:
    Theater:
  • vcwatkins
    vcwatkins Posts: 1,992
    Or this stuff? Mapleshade recommends for tube pins among other applications.
    The Wurth stuff is automotive. I'd use very sparingly.
    I use DeOxit cleaner on the pins, I don't use anything else. I have put Pro-Gold on gold pin tubes. If I had some I'd probably use it simply because the extra lube might help with really tight sockets, like in my Avant pre.
  • mikeyb128
    edited July 2016
    The wurth stuff isn't a paste either. You apply it and let it dry. Just a thought, I like small free tweaks that may make a difference.
    The data sheet says 1.4g of silver. But it's not too informative.
    2 channel:
    Theater:
    I'd be most worried about any build up or flaking left in/on tube sockets. 9 pin sockets are almost impossible to clean.
  • mikeyb128
    heiney9 wrote: »
    This was my exact worry. I'm going to skip it. I don't need to open a can of worms.
    2 channel:
    Theater:
    Wurth makes good automotive products. I bet it's designed to "apply" to electrical connections and prevent oxidation/corrosion. Not sure it's best application is tube pins.
    txcoastal1 Posts: 13,519
    mikeyb128 wrote: »
    heiney9 wrote: »
    Dab or spread a thin layer onto some metal with a Qtip and let it set for a couple weeks to see if it changes consistency.
  • mikeyb128
    Picked up a whole sleeve of these for the shanling:
    1968 GE 5 star, black plate. a whole sleeve of them with the same date codes. 29 bucks plus 11$ shipping. Not too bad considering the price I've been seeing them go for. Usually around 120-160 for a quad.
    2 channel:
    Theater:
    edited July 2016
    nbrowser wrote: »
    And this thread has gone down the tubes... :open_mouth:
    I think it's totally tubular dude
  • lightman1
    Tube Snake Boogie....
