FXi A6 or RTi A3
Not sure what speakers to choose for rear surrounds, FXi A6 or RTi A3. Currently I have RTi4s. I Have RTi12s for fronts and CSi6 for center. I want to go with a 6 1/2" driver for rears instead of the 5 1/4" that I have now. Placement of the speakers are on stands about 6' behind the couch at ear level.
  • trj
    trj Posts: 320
    Question is, do you have 5.1 or 7.1?
    If you have 5.1 and wanted to replace side surrounds, I would go with FXi's on the sides and probably use your RTi4s for the rear surrounds or front heights.
    If you already have a 7.1 system and trying to replace the rear surrounds from RTi4s, unless you are going for symmetry, I dont think it will give you much gain.
    But if you have 5.1 and have the RTi4's 6' behind the listening position, the placement is all wrong. Move them to the sides, may be slightly behind the line of listening position and re-calibrate.
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
  • dalylaleahthor
    I have both speaker that you mentioned. I prefer the fxia6 for rear surrounds but that is just my preference.
    Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
    Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
    Stuff laying around. Too much to list but don't want to sell either.
  • gp4jesus
    gp4jesus Posts: 2,025
    My take on RTi A1 to 'A3 (5.25" to 6.5") mid is go for it! Can't say on RTi versus FXi
    http://forum.polkaudio.com/discussion/173492/rti-a3s-wall-mounted-as-surrounds#latest
    *all connected w/Premiere ICs
  • mantis
    mantis Posts: 17,691
    There is so such speaker as a rear surround. Lets speak proper here
    5.1 system the surround speakers are just called surround no matter where you place them.
    7.1 you have Surrounds and then surround back. For the surrounds and surround back channels it's best if you use the same exact speaker all the way around.
    FX style bipolar or Dipolar designs where designed for Dolby Pro Logic to give it a more spacious sound. Dolby digital and DTS formats direct firing speakers work better.
    Preference has no meaning here except to the person using them. Bipolar or dipolar designed speakers can be used for the newer digital formats as it can create a more spacious surround experience and this is again preference not correct for the format.
    Dan
  • gp4jesus
    Touché, sir! The driving signal dictates its purpose as much as its position. Keep us humble.
    I've seen some use the same model for left & right rear as L&R front, floor standers no less!
    Thnx, Tony
  • rpf65
    rpf65 Posts: 2,127
    Personally use the RTI A3's as rears and FXI A6's as surround l/r. Have the rears positioned about 6 feet from primary listening position, and do to room limitations, the surrounds are about 1 foot behind the primary listening position.
    Long way of saying that if you are positioning the rears fairly far back, direct firing speakers seem to work better imho. If you have limited space behind you, say 3 feet or less, I would go with bi-pole/di-pole speakers.
    Of course as always that is a personal preference.
