RM6600 Satellite won't stay on speaker stand
gores95
gores95 Posts: 2
edited March 2004 in Troubleshooting
Hi I have the RM6600 5.1 setup and like it very much. Problem is on one of the rear satellites the screw that attaches to the speaker stand has fallen out of the speaker.
Can this be replaced? It will not stay in the speaker.
Thanks,
Marc
Post edited by gores95 on
  • ken brydson
    ken brydson Posts: 8,792
    edited March 2004
    Are the threads stripped out? If so, you might try a sheet metal screw that's slightly larger than the original. Just a thought.
  • gores95
    gores95 Posts: 2
    edited March 2004
    I am now looking at the manual. The satellites are RM2300 and the threaded insert that is supposed to stay in the back on the satellite has fallen out. The screw does screw into the insert, but the insert does not stay in.
    Do I need a new insert? Any advice?
    Thanks.
  • phoneisbusy
    phoneisbusy Posts: 867
    edited March 2004
    So, the insert is loose? Does the insert fit snugly back into the back of the speaker or is it really loose? If it's snug, I'd try to epoxy it back in.
    Perhaps some other members have a better suggestion though.
    good luck
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
