my tv doesn't have digital optical cable hook-up for my soundbar 5500
Is there another way to hook up to tv? I have it hooked up now through cable box but the volume is off a little bit from peoples lip movements on tv
  • recoveryone
    recoveryone Posts: 929
    How about giving us more info on all of the equipment being used .......make and model
  • tv is Philips/Magnavox-model 55pfl3907/f7
  • soundbar is polk 5500 from sam's club
    msg Posts: 10,510
    Quick lookup and review of manuals for both of these devices
    http://www.polkaudio.com/Media/POLK/product-manuals/sb5000IHT-3langwebmn.pdf
    http://www.usa.philips.com/c-p/55PFL3907_F7/55-inch-class-po
    From page 7 of the soundbar manual
    From your tv's spec page
    Looks like your tv still offers digital out, but it's digital coax not optical.
    If you're not getting satisfactory results with the audio from the cable box to the soundbar, you could try one of these converters that changes coax to optical. My parents' tv was the same way, and this converter did the trick; $12. Be sure to add to your order a digital coax and optical cables as well for best results.
    http://www.monoprice.com/product?p_id=2947
    Another option is to get an RCA > 3.5mm stereo cable, and connect that from your Audio Out jacks on the tv to Analog Input 2 on the Soundbar.
    http://www.monoprice.com/product?p_id=665
    I'd probably go with the converter, personally. Should be a stronger, cleaner signal to the soundbar than the analog. Not sure how much processing the Soundbar does with respect to the subwoofer portion of the system, but you might be handicapping it to a degree if you only feed it an analog signal.
  • Awesome, Thank you very much msg!!
    msg Posts: 10,510
    you're welcome, man, good luck, let us know how it works out for you.
  • received converter in mail today and hooked it up and it works great, exactly what I needed. Thank you so much for the answer to my problem!!!
    nooshinjohn Posts: 26,042
    Happy it all worked out, but you blew a big opportunity to convince your significant other that it's time to upgrade. Once they learn there is a cheaper solution, they will never go along with letting you spend another penny! :D
    msg Posts: 10,510
    Nice, good job! Fun, huh? B)
    A correction regarding
    On a second look, I was mistaken about this other possible option I noted before. Both of those RCA audio ports on your tv are for inputs, so it looks like your only option here was the digital coax, after all. Sorry, overlooked that the first time around.
