PSW111 Service Manual.
corujaoj
Hi, I have a PSW111. It was put in wrong voltage (220v). Please, I need a service manual to fix it. Someone can help me?
Answers
Hello,
There really isn't a service manual but you can probably get a copy of the amplifier's schematic from Polk's CS department at 1-800-377-7655.
Regards, Ken -
Hello! If anyone has the schematic/diagram/service manual for the Polkaudio PSW111 (100V-240V switching power supply), could you please email me a copy? Thanks.
Hello,
Welcome, schematic sent. -
If the fuse blows again or there’s no power at all, inspect the power supply board for burnt components or damaged capacitors. These are common failure points after a voltage mismatch
Hello there
so its the year of our lord 2026 and this guy started to have an audible heart arrhythmia
its highly likely that the issue is SMPS power caps related
unfortunately i do not have so much free time to debug and reverse engineering the schematic as my times as a n EE student back in the days
so if you guys can provide me with the schematic i would appreciate it
regards from the country of the tacos and pyramids
Hello!
Schematic sent. Good luck with the repair!
