Monitor 5A 1983 USA Peerless crossovers
I have a set of the above that I plan on redoing the crossovers on eventually. What is the difference between the long back caps vs the dark blue light blue versions? Was one potentially better than the other back in the day? I also ask because I picked up a spare pair of crossovers from the same year speakers and they are a mix of the two. One crossover has both black caps, and the other has one of each. They I think they are both original. One of mine has both blue caps, also original.
I have also been looking for history on the 5's. It seams there was a lot of variation, mixing and matching in the early 80's including MW's, PR's and a change in cabinet size. Has any of this been cataloged anywhere. I have yet to find it. I found a reference to "Stan's threads" but I am not sure which those are.
http://forum.polkaudio.com/discussion/158975/monitor-5a-crossover-oddity-and-other-weirdness
Did the Monitor 7's have the same variations? I don't think the cabinet size or the PR changed, but I gathered the MW's and tweeters did.
