RTA12C'S placement (fact. recommended )
Just curious what the "original user guide" suggusted. IE: how far from back wall, side wall and distance apart from each other. Does anyone know or have an original manual??? I have a late rta12c's (mw6501's)
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
  • soundfreak1
    soundfreak1 Posts: 3,414
    Wow, someone has to have this info squirreled away somewhere.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • dkfreebird
    dkfreebird Posts: 1,188
    I googled it and it shows up on manualslib.com.It shows 3ft from sidewalks and toed in and about 8ft back to the listening position.It also shows 8 to 16ft apart.Hope this helps.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • Nightfall
    Nightfall Posts: 10,083
    I liked mine with lots of toe in because it solidified the images within the soundstage. I had the tweeters pointed directly at each ear. So left speaker tweeter, if it had a laser pointer coming out of it, would be aimed at my left ear, same for right. There really is no right or wrong with "regular" speakers (read: not SDA's) just experiment.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • soundfreak1
    I was just curious as I have some room to play around with it. Wanted to get a starting point. Thanks.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • westmassguy
    westmassguy Posts: 6,850
    The on axis and 30 degree off axis response of the dome tweeters are nearly identical, according to one review I read. Lots of wiggle room.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
