Question about Sw80 swap.
I have a set of polk monitor 5 + and a pair of RTA11tls. One of the 8 inch radiators on my RTAs is busted (SW81), would I be able to use my monitor 5's 8 inch radiators (SW80)? I figured due to no voice coil or magnet assembly as long as it mounts it should perform as normal. Am I correct in that assumption?
Thanks I advance!
  • Nightfall
    Nightfall Posts: 10,083
    They're likely weighted and therefore tuned differently. It would work but it would change the bass. How much, I have no idea.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Just unfortunate that they no longer sell those replacements. Seems like running across them would take some time. Thanks for the information!
    F1nut Posts: 52,101
    Your assumption is incorrect. The reason PR's of the same mounting size have different model numbers is because they are not the same. They are tuned to each speaker model by weight. You can mount the SW80 without issue, but the bass response and character will change.
  • Do you believe a recone would be best in this case? Would that possibly have the same effect in changing the bass response depending on the material they use?
    F1nut Posts: 52,101
    To the best of my knowledge, there are no suitable rubber surrounds available for the vintage Polk PR's or mid-drivers. Your best bet is to keep an eye open for a replacement on sites such as eBay.
    F1nut Posts: 52,101
    edited February 2016
    Sorry, I checked the wrong model. Anyway, they do come up. Good luck.
  • Thanks on it!
  • Can't seem to find it. Are you able to link?
  • westmassguy
    westmassguy Posts: 6,850
    Home Theater/2 Channel:
    dhsspeakerservice.com/
