Larry's rings or Hurricane nuts?
dLarry graciously was able send me his rings for my SDA SRS 2s. I already have hurricane nuts and was wondering if it's worth the time and trouble to install them considering I already have the hurricanes. If not, I'd be glad to pass them on to someone else.
  • I had been meaning to ask someone on here what the difference is
  • JPete
    JPete Posts: 298
    Probably not a huge difference, but the rings are nice.. I'll take the MW driver rings from that kit if you really don't want them.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • Hey I responded first
    I want'em too waaaahhh
    I have some 3.1tl's though
  • JPete
    JPete Posts: 298
    I just did the rings on my CRSs, and was planning on doing the Monitor 10s if I ever get around to the crossovers.... Then I also thought about just using hurricane nuts. As of this minute I'm thinking about selling the 10s and looking for something different...
    You can have the rings man.
    F1nut Posts: 52,101
    The rings are definitely the way to go if at all possible. If not, Hurricane nuts are better than the standard wood screw fasteners.
  • I used the hurricane nuts when the rings were not available. They are fine no issues.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • machone
    machone Posts: 1,572
    I have used both.
    I thought the rings were easier to install and will not spin. I had one hurricane nut crossthread and spin when I tried to back the screw out.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Toolfan66 Posts: 18,258
    Larrys rings for the win.. :)
  • Mike Reeter
    Mike Reeter Posts: 4,315
    I just replaced the Hurricane Nuts in my 2.3TL's with Larry's Rings (Larry wasn't making any Rings at the time I first rebuilt them) and yes I can hear a difference. The imaging is tighter and clarity in the mids is sharper.
    This batch of Rings is my fourth set, wouldn't be without them if at all possible.
  • MrBuhl
    MrBuhl Posts: 2,419
    I have both, but have only ever installed the Larry Rings, (got in on a fresh run right after I bought the h-nuts). Heck, I even have a set of Larrys Rings for a "future" set of Polks I don't even own yet, but want to and didn't want to be without when/if I finally pull the trigger :blush: LOL. They're super easy to install and the way to go IMO.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    txcoastal1 Posts: 13,519
    As long as you don't mix things up and have Larry's nuts your good
    pitdogg2 Posts: 27,486
    MrBuhl wrote: »
    You and me both :D
  • westmassguy
    westmassguy Posts: 6,850
    Hoarders.....
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • teekay0007
    teekay0007 Posts: 2,288
    txcoastal1 wrote: »
    That's what she said... :p
    I have four pairs of speakers in the house that have Larry's rings (and nuts!) on them - one set installed by the master himself - and am VERY happy with all of them. So....smoke 'em if you got 'em! I mean...might as well use the rings you have.
  • cortico
    cortico Posts: 587
    machone wrote: »
    ...I had one hurricane nut crossthread and spin when I tried to back the screw out.
    use a dab of epoxy glue between the hurricane nut and wood, make sure to tighten before the glue cures, this will keep it in place.
