Orientation of Bi Polar Clarity Caps
VSAT88
VSAT88 Posts: 1,367
edited February 2016 in Vintage Speakers
I read somewhere that even though a bi polar capacitor can be installed either way that there was indeed a better way to connect it by using the bulge on one side to the positive side or something of that sort. Anyway, I have ClarityCap ESA thanks to Vr3 and I would like to know if there is a better/best way to install them as I see no bulge of any kind. Both sides of the capacitors are flat. Thanks.
  • VSAT88
    VSAT88 Posts: 1,367
    Decided to just go for it. Thanks for looking though.
  • mikeyb128
    mikeyb128 Posts: 2,885
    I asked vr3 this same question when building my crossovers, he said it doesn't matter. So I placed the writing the proper side up so everything on the board looked uniform.
    2 channel:
    Theater:
    F1nut Posts: 52,101
    The longer lead is connected to the outer foil (shield) and should be connected to the negative side or ground. You may or may not be able to hear the difference.
  • VSAT88
    VSAT88 Posts: 1,367
    mikeyb128 wrote: »
    Thanks, I did the same. I looked at a few images as well.
  • VSAT88
    VSAT88 Posts: 1,367
    Thanks F 1. That is exactly what I read somewhere. I will document for future reference. Come to think of it, I would like to know how to identify the foil end as well.
  • soundfreak1
    soundfreak1 Posts: 3,414
    I used the ESA'S as well in my rta12c's with fantastic results. Never heard of" direction" before. But also have no issues.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • VSAT88
    VSAT88 Posts: 1,367
    No issues whatsoever here !
  • machone
    machone Posts: 1,572
    Do Sonicaps have a longer lead on the foil side?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • westmassguy
    westmassguy Posts: 6,850
    machone wrote: »
    No
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Schurkey
    Schurkey Posts: 2,122
    Do bipolar capacitors have quirky personalities if they aren't given medication?
  • soundfreak1
    My tech told me the ESA'S are bi-sexual not bi-polar as they go both ways.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • VSAT88
    VSAT88 Posts: 1,367
    Schurkey wrote: »
    Are you saying that I needed Lithium capacitors or can I just sprinkle some of my Lithium on them ? How about adding some Seroquel, Cymbalta and Lamictal while I am in there, would that help ? I would hope they do not become manic or too depressed to work after that. Adding it would not be a problem when I go back in to dampen the drivers and I already have plenty, really, I do.
  • Schurkey
    Let's just say that I prefer the term "non-polar" to "bi-polar", although both are in common usage.
