Nice Denon PMA 2000IVR high current integrated amp with remote and phono
geppy1
geppy1 Posts: 3,076
edited January 2016 in For Sale (FS) Classifieds
For sale is a very nice Denon PMA 2000IVR with the very hard to find remote,phono stage power cord and copy of the manual.. The unit perfectly as it should. This is the latest and improved version of the PMA 2000R which was on Stereophie's recommended List for a few years. The IVR is more involving and dynamic then the R version to my ears. Uses Ultra High Current MosFets and a true dual mono design. Puts out 80 per channel into 8 ohms and 160 into 4 ohms with over 100 amps of current available. Can drive almost anything . One of the few amps I have heard that produces an almost holographic stage with some tracks. Has a very nice phono section and part of the change over the original 2000 is the inclusion of a preamp out and a poweramp direct. This allows you to use it in a HT system if need be. The feel and build quality is off the charts. It weighs 52lbs. It is in very very nice shape with a scratch or two on top and on the backside left lower corner of the faceplate there is a very small dent. It is on the side/backside so many would not notice it. More info below. Asking $495 or BO which is on lower end as they sell for up to $650 Thanks
PM for pictures
Product Identifiers
Brand Denon
Model PMA-2000 IV R
MPN PMA-2000 IV R
Key Features
Frequency Response 5 Hz - 10 kHz
Number Of Channels 2
Tech Details
Audio SNR 74 dB
RMS Power at 4 Ohms 160 Watt
RMS Power at 8 Ohms 80 Watt
THD (Total Harmonic Distortion) 0.01 %
Remote Control Without Remote Control
Bridgeable Not Bridgeable
Dimensions
Depth 18.75 inch
Height 7.1 inch
Width 17.1 inch
Weight 52 lb
  • marvda1
    marvda1 Posts: 4,960
    had one for a while, it is a beast. add a tube preamp to it and you have a killer combo as the preamp section is its weak point. made my ushers sing.
    glwts
    Puritan PSM156
  • zingo
    zingo Posts: 11,258
    My brother-in-law uses one of these with his NHT Classic Fours and it's a great combination.
  • deronb1
    deronb1 Posts: 5,021
    52 lbs? Holy shniekies!!!
  • Do you still have the denon 2000ivr for sale?
  • rooftop59
    rooftop59 Posts: 8,120
    You mean from 2016?!?
    Game Room 5.1.4:
    Bedroom 2.1
  • geppy1
    geppy1 Posts: 3,076
