SDA 2 question
oldrocker
FYI, I'm in the process of letting the adhesive dry on the side panels as they were loose and I noticed a screw to the left of the speaker connections " 2nd pic" and was wondering what is that screw attached to internally?
Thanks all.
Thanks all.
That's the Hex-Head Cap screw holding the CrossoverHome Theater/2 Channel:
dhsspeakerservice.com/ -
Thank you Sir!!!!
WelcomeHome Theater/2 Channel:
I think i read that some of these cabs have posts that connect them to the wall. This is supposed to somehow enhance sound??
It's called the bass brace.Home Theater/2 Channel:
