denon 3808ci
So my receiver wont turn on. I switched it to the yamaha and it turn on. I was just watchimg a movie on it 2 days prior. Any tips?
Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
Stuff laying around. Too much to list but don't want to sell either.
  • ken brydson
    ken brydson Posts: 9,058
    Missing my secret decoder ring. Have you tried a hard reset on the Denon?
  • Will do. I'll let you know what happens.
  • rooftop59
    rooftop59 Posts: 8,120
    My only two suggestions would be Ken's and possibly a fuse, but those receivers are usually not that simple. Hopefully you can fix it, but its not a new unit. It might be toast. Did you have a power outage or anything beforehand?
    Game Room 5.1.4:
    Bedroom 2.1
  • Thanks for the input. It did rain pretty hard the day before as I'm in California with the suppose El Nini but I do have a surge protector and hopefully that'll come into use one day. I did what Ken did and it worked(took some time to get to it as I have been real busy). I was thinking about the worst case scenario and that would have been a new receiver at over 1k dollar. Thanks for all the help guys. It is much appreciated.
  • Upstatemax
    Upstatemax Posts: 2,839
    If it's anything like my old 2808, look to the right of the power button.
    There is a "On/Off" switch, make sure it was not bumped.
