Model 10 tweeter
I have my M10 up and running. I am interested in replacing the tweeters, then possibly doing the x-over upgrades. How do I tell which tweeter this?
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    Those appear to have already been replaced with the RDO-94.
  • akajimmy
    Really? That is very interesting. Looks like the crossovers are up next :)
  • westmassguy
    westmassguy Posts: 6,850
    No, those are most likely SL2500s. Pull one and check the label on the back.
    The replacement for them is the RDO-198-1.
    Looks like someone replaced one of the woofers, and didn't notch the rubber surround.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • TNHNDYMAN
    My mistake. Should have seen that since that's what I had in my 2.3TL's.
    pitdogg2 Posts: 27,597
    yep this ^^^^
  • StantonZ
    StantonZ Posts: 454
    edited December 2015
    Can you explain this? Even if I could see it in the pic, I'm not sure of the significance.
    To the OP: I replaced my SL2500's with RDO-194's (198's require changes to the XO) and re-built the XO's and am very happy.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • Nightfall
    Nightfall Posts: 10,083
    StantonZ wrote: »
    Look at the first picture. Notice the rubber around the screw on the right midwoofer compared to the left.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • StantonZ
    StantonZ Posts: 454
    Nightfall wrote: »
    StantonZ wrote: »
    OK: I think I see the "pinching" going on with the right side. So what's the (sonic) significance?
  • westmassguy
    StantonZ wrote: »
    Not a sonic problem, it's a installation and lifespan problem. The rubber surround has been stretched, possibly torn, and the adhesive bonding the surround to the frame may be compromised.
    The correct replacement for the SL2500 is the RDO-198-1, not the RDO-194-1.
  • StantonZ
    StantonZ Posts: 454
    StantonZ wrote: »
    Oops...I must have had SL2000's, because I know the 194 was the replacement. I should edit my other post.
  • akajimmy
    I did replace that woofer. DId not even think about notching it. Just very carefully cut a triangle with a sharp hobby knife?
  • westmassguy
    akajimmy wrote: »
    Either copy the notch like the originals, or cut a half circle. I use a bolt and nut as a guide, and carefully cut around the head, leaving a minimum 3/16" of rubber still attached.
    Round is better than sharp corners, less stress, and less chance of splitting as the rubber ages.
