Have SDA2A - Want SDA2BTL
MrBuhl
So I found out (via installing Larry's Rings) that I had SDA2A's and not the 2B's I had always thought they were. Still happy speakers, but I just couldn't get over that longing for what I thought I had. Cabinets are about the same... already have the rings installed, dynamat on drivers, cabinets sealed and No-Rez, in fact early on I think they even used some old 2A cabinets on 2B studios if I recall - why not?
Picked up some bargain drivers from Deron's part-out, along with a set of modded 2B crossovers. Then Partsconnexion had their 25% off sale, and I said what the hell... in for a penny, in for a pound... so I picked up some ESA series Clarity Caps and the requisite Mundorff resistors to TL them and I was off to the (turtle speed) races with Dave as my guide! (he's prepping some Erse inductors for me now too!). Interesting work for JoeHomeOwner.
Here's the start point on the crossovers and finished (but untested) product. I have the 198's from Polk's dependable customer service dept. Just need some time to test and put it all together! Already have an 800v/a Dread for them, so it should ramp up nicely. Plan to use these with the Dodd MLP and 50W. Yummy!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Looks great Ed.Home Theater/2 Channel:
dhsspeakerservice.com/ -
HEY Nice one ED!!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thanks guys, the proof is in the puddin as they say but I'm hopeful!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
New Erse inductors arrived today from Westmassguy - Thanks David they are perfect as always!
Hooked everything up for some tests, and miraculously, worked like a charm first time!
Made some stand offs for the crossovers from heavy nylon tubing I had around, and mounted crossovers thru them with stainless screws. Covered existing SDA connection hole with a couple of stainless fender washers (and some neoprene washers), cinched with a stainless bolt for a good airtight seal. Mounted the Erse's with stainless screws.
Now to button them all up for the real weekend test - listening!
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Looking good Ed.Home Theater/2 Channel:
Thanks David - and thanks for all your help with them!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
