Will a Sonos Connect Amp power Polk SDA-2A speakers?
I have a pair of Polk SDA-2A speakers (at least that's what the manual says; the speakers just say "2" and have the pin/blade interconnect, rather than blade/blade, so they might be a transitional model).
I'm was driving them with an old Sony ES receiver and am considering a Sonos Connect Amp instead. Not as much power as the Sony (about 1/3rd, I believe), but I'm told the Sonos amp "should be" good enough. I did hook up the Sonos to the speakers briefly (without the interconnect) and they seemed to work, but I was reluctant to experiment too much.
An alternative for me would be to get a Sonos Connect (no amp) and get a new amp with more power and common ground.
Best Answer
  • hochpt21
    hochpt21 Posts: 5,423
    Answer ✓
    Amplifier Class-D
    Rated Output 110W RMS (2x55W continuous average power into 8 ohms, THD+N<0.02%)*
    I would not do it.
    I would go for your second thought.
Answers
  • hochpt21
    Welcome to the forum BTW...
    txcoastal1 Posts: 13,519
    I have both the Sonos Connect and the Amp. Originally had the Amp powering a set of Polk TL-3 and using sub out on a Polk 110 sub for my desk top rig which was fine.
    I then purchased a used set of LSi7 and paired w/ Sonos Amp that didn't fair well.
    I bought a Dayens Ampino and now using Sonos Connect with great results for my desk top rig.
  • jtkorb
    jtkorb Posts: 10
    Thanks to both of you for your responses. I'm now looking for a low-cost amp to use with my SDAs.
  • westmassguy
    westmassguy Posts: 6,850
    jtkorb wrote: »
    Welcome to CP. If they have a pin/blade interconnect, they're 2Bs, not 2As. Big difference.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • jtkorb
    jtkorb Posts: 10
    Well, I am confused about the nomenclature. But, I've now checked the serial numbers: 16650 right and 18675 left, which seems to indicate that they are, in fact, 2Bs. They do look like the 2Bs pictured here. I may have to take one apart... :smile:
