AVR for Polk RTI A7's
Hello all,
just bought two Polk RTI A'7s to start building my audio system, and I was wondering if the Pioneer Elite VSX-80 7.2-Channel Network A/V Receiver is a sufficient AVR to power them. I'm a bit strapped for cash so I'm looking for value. Thanks for any help.
    F1nut Posts: 52,406
    Are you building a 2 channel music system or an HT system?
    Yes that receiver will drive them, not to their best ability though. For HT use, that receiver should suffice but for music listening better options are out there.
  • mantis
    mantis Posts: 17,694
    No man I'm not feeling that receiver for the RTIA7's. Yes it will make sound but I feel if your strapped for cash go used and get a SC model. They have way more power and will power the RTIA7's wonderfully.
    I'd look at the SC-65. You will get a better deal on that then a new VSX-80.
    Dan
    edited October 2015
