Out of phase
So I re-ran the auto calibration as I had adjusted the setting to many times and felt the sound was off a bit.
Well after I ran it it said the front mains were out of phase weird.
I ran it again thinking that it was just an error but nope same results.
Checked the wiring everything is good ran it again same same.
My AVR is a Yamaha 2040 and it used Ypao.
Have anyone else have this happen?
Now the front mains sound just sublime so it just the fact that something may be wrong that bugs me.
Thanks, Roger
  • polk500
    polk500 Posts: 1,171
    Hmmm now that you mention it you may be right I will search it and see if I can find that thread.
    Cheers, Roger
  • mikeyb128
    mikeyb128 Posts: 2,885
    Your lsim are out of phase due to the crossover design. My marantz does this as well, and so did my pioneer. It's normal though, so don't worry.
    2 channel:
    Theater:
  • polk500
    Mike I just read a thread by dpowell and he has the same issue. But that's good you guys have the same reading but nothing is wrong with the speakers or the AVR.
    Cheers, Roger
  • mikeyb128
    Avrs do a pretty good job. But I ignore them if everything is confirmed hooked up correctly. I've had room reflections cause a speaker to look as though it was out of phase, simply moving it further away from the wall fixed the issue.
    2 channel:
    Theater:
    tonyb Posts: 33,072
    Yep, ignore it dude, won't hurt anything.
    I've been out of phase my whole life, doesn't bother me none. Drives those around me crazy though.
  • Msabot1
    Msabot1 Posts: 2,098
    tonyb wrote: »
    How many degrees TB??...I figure that I've been off about 180! LOL!!...
    tonyb Posts: 33,072
    Msabot1 wrote: »
    tonyb wrote: »
    That depends on who ya ask. LOL My kids are more generous, but the wife would tell you they haven't even discovered a phase yet for me to be in a phase.
  • mikeyb128
    I'm in a 2 channel phase as of now :blush:
    2 channel:
    Theater:
