Mortite vs Armacell
I have been reading through some of the posts comparing Armacell to Mortite. The consensus, plus DK's analysis, seemed to be that the Armacell outperforms Mortite when used in conjunction with Larry's rings. I will be using hurricane nuts on my SRS 3.1TLs. Armacell is so much easier to work with that I would prefer to use that. But is there any reason to prefer Mortite with the hurricane nuts?
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
    nooshinjohn Posts: 25,876
    None.... Go Armacell
    F1nut Posts: 51,673
    If the stock gaskets are not damaged there's no reason to change them.
  • Well, the press test pushes the MWs out for 1-2 seconds. Given the size of the SRS 3.1TLs and the number of openings, is that normal?
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    Should be about 3 and a half...
    F1nut Posts: 51,673
    Are you pushing and holding the PR in or are you pushing and releasing?
  • F1nut wrote: »
    This^^^^^^^
    Once the Hurricane Nuts and machine/cap screws are installed, you can tighten the Woofers and PRs much easier. You should inspect all the gaskets before hand, and make sure they're intact, and usable. I would recommend replacing the Tweeter gaskets however. The plastic bezels are easily deformed if tightened too much, and the old gaskets may not seal properly.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • F1nut wrote: »
    Push and hold.
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • Thanks, everyone. It will be a while before I get them back together. I will be JB Welding the magnets, Dynamatting the baskets, and replacing the IC sockets first.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • Use Loctite Power Grab instead of JB Weld. Dries Clear, cleanup with soap and water.
    Can also use it to re-seal the cabinet interior, as it contains no silicone.
    That title almost sounds like a discussion about munitions? Even though I know what both items are, lol
  • We fought off the Loctite Power Grab until our Mortite ran out and the Armacells overran our defenses.
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • My gaskets were shot so I also went the Armacell route. All you need is a sharp blade, cutting surface and some minor measuring and is very easy to work with. I think the roll cost me around $8 at Home Depot . Never even considered Mortite as a caulk would be way more messy. I also used Larry's Rings.
    edited September 2015
    jimbo1421 wrote: »
    That's pretty good, jimbo!
    I have some Mortite around. I believe I used it to seal, not speakers but some drafty windows in my old house last winter. It can be messy, depending.
    F1nut Posts: 51,673
    If you mean compressed to hell (paper thin), they should be that way. Any new gasket material should also be able to be compressed to hell otherwise the basket is not really one with the bezel as it should be.
  • Jesse if your talking to me then no, When I pulled out the drivers to do the Dynamatting most of the gaskets either disintegrated ,fell apart when pulled off and a least one was so thin and stuck to the driver it looked weathered and beat to me. So my argument of having pristine stock 2Bs in a 20 something year old coma went by the wayside after being told that age, sun, room temp and modern mods will bring those to better than spec was true and I'm getting no leakage w/ using the Armacell / Larry's rings combo.
  • skrol
    skrol Posts: 3,437
    Which Armacell product are you all using?
    Stan
    Main 2ch:
    HT:
    Other stuff:
