Sharp LC-70LE660U or Vizio E70-C3
I have these both TV and not sure which to keep, any thoughts here would be a lifesaver.
Per my assessment:
Sharp....is sharper imagewise but SOE is notorious with fix via firmware upgrades. Has a power supply issue as well, couldn't turn it Off or On using remote or the button on the tv, must use the good old plug.
Vizio..........not quite impressive but reliable? I dont know. I just know that issue may arise after 1yr or 2yrs of use.
PLease advise POLKIES
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
  • mrbiron
    mrbiron Posts: 5,721
    Well, since you "have these both tv" i would suggest scrap them both and get something reliable....crisis averted!
  • Nightfall
    Nightfall Posts: 10,083
    Out of these both TVs I'd think imagine keep the Vizio.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • rooftop59
    rooftop59 Posts: 8,120
    That's a lot of scratch to spend on something ur not really satisfied with. I agree, return them both. Surely there are other 70 inch options? Heck, I would rather go down to 65 and have something I was really happy with.
    Game Room 5.1.4:
    Bedroom 2.1
  • mantis
    mantis Posts: 17,609
    Agreed with the above comments.
    I for one am not a fan of either company. Get rid of them both and get a Sony.
    Dan
    If you want to go big TV's on the cheap, Visio is hard to beat, but you do get a cheaper set all around. Their top TV's aren't bad though. Sony or Samsung would be my preference in that order.
    Since all TV's are going computer based, all TV's are going to come with glitches, firmware upgrades needed, etc. None are built to last anymore....which is depressing seeing what they cost these days. Sony and Samsung seem to have the better quality though if 3d is important to you, I think Samsung does it better than the Sony's. Sony however has the better picture but not by much. Both will upscale 1080p content to close to 4k resolution which is a big plus when done right .
  • Polkie2009
    Polkie2009 Posts: 3,834
    Speaking of 3D, does LG's 3D tv sets even compare to the Sony or Samsung 3D reproduction?
    It's a crap shoot really. The higher end models usually do well with 3d across all brands. If your shooting for cheap though, that's what your gonna get.....along with motion blur, back light bleeding, quirky internet connections.
