rough corners on speakers no problem
leftwinger57
My '78 M7s have some what appears to be chewed upon corners and dents from multiple moves. Some suggested build it up w/ wood dough or similar stuff and me w/ no woodworking skills took this route. Keep in mind if to shinny for you they could always be distressed or even painted. These came from Home Depot for a whopping $3.25 for a set of 4. I think it solved the torn corner problem and don't look all that bad. Now I need another set for the other speaker
Good! Now, do you have any of that "black paint" everyone around here seems so "concerned' with?Currently orbiting Bowie's Blackstar.!
..lol if I decide to paint or just distress would be some sort of brown wood tone. That of which you speak would be my world famous flat black but not for this. Way easier way of concealing dented or chewed corners on the cheap.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
What a great solution, quick, easy, and cheap. Who would argue with that?
Stereo
Home - Sansui SR-4050c, Sony PS-5500, Kyocera DA-610, Pioneer SA-1000, Monitor 10A
Work - Marantz 6100, Alternative Acoustics preamp, Oppo BDP-83, Pioneer Elite VSX-53, Def Tech SM350, Klipsch KG2
HT - Mitsubishi HC6500, 106" screen, Panasonic 50" Plasma, Oppo BDP-103, Toshiba A35, Panasonic LX-1000U, , DirecTV H21-100, PS3, Pioneer Elite SC-85, Def Tech; SM 450, CLR 2002, BP2X, Klipsch KSB1.1 (Atmos), Pro Sub 100, Polk PSW125
Living Room - Mitsubishi FD630, 92" screen, Samsung 40" LCD, Panasonic DMP-BT330,
DirecTV HR24-200, Yamaha Aventage RX-A1030, Polk; CS1, RC80i (4), Klipsch Sub10 -
Where do you get black paint?Home Theater/2 Channel:
dhsspeakerservice.com/ -
That works! Kinda gives them a "pro" look.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Dave by now you should know I get my World Famous Flat Black at Home Depot about 2-3 minutes from me. I must have painted 3 racks numerous shelves but NO devices...lol Oh, I did get another set and both M7s are done.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Home Depot has paint?Home Theater/2 Channel:
