Alternatives to BOSE WAVE III System?
My wife got me Bose wave III system for my birthday. Exactly what I need - good looking portable cd player that's not a "boombox".
The only problem with this bose piece is that there's no bass and sound gets "noisy" when loud. I do realize there's only so much bass without a subwoofer so I'm not looking for a 5 star restaurant at McDonalds prices but is there a better option? Willing to add a few hundred bucks if needed but better sound at higher volumes and deeper bass would be nice.
2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
  • Mikey081057
    Mikey081057 Posts: 7,127
    #2 pencils thru my ear drums
    Garage | Polk Monitor 5B's
  • Inspector 24
    Inspector 24 Posts: 1,308
    Smart **** answer: Anything but Bose for 1/3 the price maybe?
    Serious answer, if you've got to have 'No Highs, No Lows, Must Be BOSE' the Acoustic wave is a big step up in sound.
    Or maybe http://www.polkaudio.com/woodbourne/d/1041C3015
    I heard it at CES, though I'd personally never spend $600 on such a thing, seemed nice for what it is.
    But in these prices you could buy an inexpensive integrated and a couple decent speakers and get arguably better sound.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Nightfall
    Nightfall Posts: 10,083
    edited August 2015
    For a few hundred you could put together something with Monitor 5 or 7's, even if it's with a cheap AVR or a vintage integrated/receiver. That's how I look at it anyway.
    How portable does this need to be? I bet these would do better, you'd just need a CD player.
    http://www.amazon.com/Klipsch-ProMedia-Certified-Computer-Speaker/dp/B000062VUO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1440052385&sr=1-1&keywords=klipsch+promedia+2.1
    afterburnt wrote: »
    Village Idiot of Club Polk
  • cfrizz
    cfrizz Posts: 13,415
    Good lord people, did you miss the fact that he wants something portable???
    mhardy6647 Posts: 35,242
    edited August 2015
    Sangean and Tivoli both make some very nice radios -- generally mono, but compact, EQ'd to decent sound at even moderate volume levels, and good radio performance as well.
    We have a Sangean in the kitchen. It fills the downstairs with sound when asked to do so, sounds good, and will receive WBZ-AM in Boston (120 miles away) day or night, too -- as long as I turn off the LED lights in the kitchen :-P
    EDIT: FWIW, this is the one we have. Obviously it is not stereo, though,
    http://www.universal-radio.com/catalog/spcialty/3281.html
    txcoastal1 Posts: 13,519
  • MrBuhl
    MrBuhl Posts: 2,419
    I was thinking Woodbourne too - but you may want more than just a bluetooth speaker.
    I've heard these - and we use a version in my hotel. Not a bad sound, but not what I would consider good bass either. http://www.tivoliaudio.com/products/hi-fi-systems/portable-music-system-three-am-fm-bluetooth-white.html
    For the cheap price, (check the refurb Polk Store on eBay) my Camden Square is a nice sounding bluetooth speaker at moderate volumes honestly.
    That Peachtree looks like a winner!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Emlyn
    Emlyn Posts: 4,827
    If looking for an all in one CD player with an am fm tuner these days, the market is pretty small. Most systems are streaming now.
    Not really anything wrong with the Bose for what it is, which is an old school table radio/cd player that apparently still sells well.
    If looking for better sound, you may need to consider entering the world of streaming audio, whether from a Bluetooth or network device. There are dozens of systems that do that in many price ranges.
  • EDUBAG
    EDUBAG Posts: 403
    audioengine has a couple of things that might work for you. the a5 and a2 powered speakers are well reviewed also they have a new bluetooth speaker that is supossed to be the a2 with bluetooth together in one body. has an extra input and seems rather nice and portable enough.
    www.audioengineusa.com no affiliation
    currently own the a2 and are great for what they are. surprisingly good!!!
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • Find a used Cambridge Soundworks CD88. A wonderful table radio designed by Henry Kloss. It has a built in subwoofer, CD player, good radio tuner, and aux input. I've had several of these over the years and they provide room filling sound and excellent bass output.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • WLDock
    WLDock Posts: 3,073
    What sources are you after? CD, radio, files, etc? Direct connect, Bluetooth, etc?
    Depending on what your needs are.....a Bluetooth device mated with a MP3 player, phone, eyc might work? ...for less money.
    The Harman Kardon Onyx Studio is a nice sounding and room filling unit with a very surprising amount of bass. Check out the TONS of reviews on the net, youtube. Also check out their other products....defiantly products worth listening to, Odd shape but battery powered and portable.
    And if you are good with connecting a player to a speaker vs. the portable wave system concept...and you 'really" want to jam on the go....the Marshall Kilburn Portable Bluetooth Speaker is a MUST listen to! As well as the JBL, and the Klipsch.
