New peerless tweeters
Braddles63
Im rebuilding a pair of 7A's and the peerless tweeters are not in the best condition. I have noticed some replacement ones on ebay. I'm wondering if anyone has tried them and if they are any good?
If not what changes i would need to make to use some rdo tweeters.
Any feedback would be great.
If you're referring to the copies from Midwest speakers(I believe) they are a very close copy and should work well. Another member here geppy1 has gave them a shot with no complaints.
Several members have used them with good results. You only other option, is eBay, for the vintage Peerless. The RDO-194 or 198 are not compatible with your crossovers.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks guys.
There is a 4 ohm and an 8 ohm available. Am i correct its the 8 ohm one I'm after? -
8 ohm is what you wantHome Theater/2 Channel:
Keep us updated on your results.
Cheers again guys. Will let you know.
