PROJECT DEBUT CARBON OR RPM1 CARBON????
Hello Guys,
Which one would be a better turntable in your opinion? the debut is 399 and the rpm1 is 499. the debut brings the 2mred and the rpm1 the sumiko pearl cartridge. I do not care about the cartridge since I have the denon dl-110 and will use it with either one if possible.
the rpm1 is a mdf platter and the debut is metal platter (can be upgradeable to acrilyc)
Which one would be a better fit to the denon cartridge and a better upgrade than my very normal pioneer pl-100 turntable?
thank you all for your opinions.
is there a better turntable than these options in that price range?
regards,
Eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
  • Inspector 24
    Inspector 24 Posts: 1,308
    Good question. From what I've read the Debut Carbon is the biggest bang for the buck, possibly more so with the acryilic platter and a good cartridge, as such it will be my pick when I finally get around to going Vinyl.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • hochpt21
    hochpt21 Posts: 5,423
    Get the debut carbon espirit. It has the upgraded platter and the speed box built in. It's like getting the two initial upgrades to the debut for half price.
    I think it's 499 or 599.
  • Upstatemax
    Upstatemax Posts: 2,785
    IIRC, the RPM series had a lot of complaints with motor noise...
    Personally, I've never had an issue with motor noise with my Debut Carbon.
  • steveinaz
    steveinaz Posts: 19,546
    hochpt21 wrote: »
    BINGO.
  • miner
    miner Posts: 1,305
    I recently bought my son a Debut Carbon for his upcoming Bday - will report back once we get it hooked up
