How to stream your personal lossless library
Hey All,
So I am upping my headphone game a bit, since sitting at work is the main time I get to listen to music. And so far I have been happy with spotify, but with a nicer usb dac/headphone amp in the mix, I wish I could listen to my lossless library at work (and no, I don't want to do tidal).
So does anyone currently stream their library? I have pled on my home computer, so I think I can open a port that would allow my to do this, but I have never done that before and it makes me a little nervous. Any advice?
Thanks!
Game Room 5.1.4:
Bedroom 2.1
  • Nightfall
    Nightfall Posts: 10,086
    Buy an external hard drive, copy all your music onto it, plug hard drive into work computer and listen?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • rooftop59
    rooftop59 Posts: 8,121
    yes that is an option. they are so small now that its not that cumbersome, but I would ideally like to be able to stream to my phone as well when I am working in a starbucks, etc.
    Game Room 5.1.4:
    Bedroom 2.1
  • Yes pled will stream your music over the web using your home pc as the server.
  • rooftop59
    Anyone know how to open a port? I gave it a quick try this morning to no avail. I don;t know much about routers, but this is the one I have:
    http://www.amazon.com/NETGEAR-Nighthawk-R7000-Certified-Refurbished/dp/B00P1Q9XNI/ref=sr_1_2?ie=UTF8&qid=1438787228&sr=8-2&keywords=netgear+nighthawk+ac1900
    Game Room 5.1.4:
    Bedroom 2.1
  • D'prived
    D'prived Posts: 191
    edited August 2015
    I don't know much about Plex but can't you log in to it via http://? I have a QNAP and log into it via the web and am able to stream my music via Music Station which is an app similar to Plex.
    http://www.makeuseof.com/tag/how-to-access-your-plex-library-from-a-remote-computer/
  • I have not tried to use another PC but have tried the android app with good success.
  • rooftop59
    Okay thanks guys the linked article should help. I will give it a try later this week hopefully. In the meantime I am grabbing my portable 1 tb hard drive with my entire collection on it and taking ti to work tomorrow...
    Game Room 5.1.4:
    Bedroom 2.1
