Annoying Subwoofer Rattle
FrstGenCamaro
FrstGenCamaro Posts: 3
edited March 2004 in Troubleshooting
I have the PSW50 subwoofer that I bought a few years ago with the RM5400 satellite speaker set-up. On a deep bass tone, like an explosion where there are no highs, there is a pretty loud rattle that comes from the rear panel of the sub. I did think that it was the hook-ups for the other speakers but I can't seem to locate it exactly. I was just wondering if anyone else has had this and if there is a way to correct it. Thanks in advance!
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited March 2004
    Hello,
    Thanks for posting on the Forum. It might be best if you telephone me at 1-800-377-7655 extension 891 and I'll be happy to solve your problem.
    Regards, Ken, Polk Audio Customer Service
