Hamburger Patties Are Directional - Like Cables
You've Been Making Hamburger Patties Wrong Your Entire Life
Julie Zeveloff - MSN Business Insider
June 10, 2015
You may have the perfect recipe for hamburgers — but chances are, you've been making the patties wrong your whole life.
Most home chefs dump their ground beef into a bowl and knead in all the fixings: chopped onion, ketchup, red pepper flakes. Then they roll the dough into balls and flatten them with their hands before tossing them on the grill.
But this method has some major drawbacks.
In a 2007 episode of the short-lived BBC show "In Search of Perfection," Michelin 3-star chef Heston Blumenthal spent six months using science to create the "perfect hamburger." His biggest revelation was that in order to achieve an "open," juicy texture, the grains of ground meat should all fall in the same direction. There are two benefits to keeping the grains of meat running straight: The first is to avoid the release of proteins that could act as binding agents, and the second is to keep the strings from becoming intertwined. Either could lead to a denser and drier patty.
This is when the famed chef's method really veers off the path of the traditional burger patty. Instead of forming patties with his hands, he rolls the entire pile of ground beef into a sausage-like tube using plastic wrap.
He refrigerates the roll for at least half an hour, and then slices it like a sushi chef, ensuring that each patty's meat grains stand parallel to one another, and that each is a consistent thickness all the way through, allowing for even cooking.
Blumenthal, whose burger blend is 50% chuck, 25% short rib, and 25% brisket, prefers to grind his own meat and have a sous chef pull the grains out of the grinder, to keep them parallel.
Blumenthal's other big trick is to treat his pan like a rotisserie instead of a grill. He flips the burger every 20 or 30 seconds, a method he says "drives a much more even temperature through the meat," resulting in a burger that's "nicely colored on outside, but evenly cooked through the middle."
http://www.msn.com/en-us/foodanddrink/cookingschool/youve-been-making-hamburger-patties-wrong-your-entire-life/ss-BBkU7de#image=5
  • Moose68Bash
    Moose68Bash Posts: 3,843
    DK,
    Only you would come up with this "tweak" to a common practice -- i.e., grilling burgers! :)
    Interesting idea that I may try. I do happen to have a meat grinder of my own.
    What do you do to get all those "fixin's" in your burgers?
  • BlueFox
    BlueFox Posts: 15,250
    This is all cooking myths. All burgers taste the same. :)
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2015
    I make mine the "wrong" way. Since Chef Blumenthal didn't mention how he puts the "fixin's" in his burgers, I assume he adds them externally after they are cooked.
  • Moose68Bash
    And we all know they taste better mixed in; so I'm sticking with the traditional technique.
    There is a difference between burgers and cables!
  • Jimbo18
    Jimbo18 Posts: 2,351
    I haven't tried his method but I KNOW mine tastes better anyway. Why spend the extra money on a meat grinder when the burger from the store is just as good? I think we need a double-blind taste test to prove it out.
  • decal
    decal Posts: 3,205
    The secret is cryo treating the meat to get that "jaw dropping" flavor.
  • Moose68Bash
    edited July 2015
    decal wrote: »
    Not to mention that special crunch of broken teeth!
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    I'm going green and sticking with pemmican,
  • Msabot1
    Msabot1 Posts: 2,098
    Well..I have found that a good burger begins with the quality of the meat that you make them out of.....next is not handling the meat as much as possible..and the fire temp when grilling them...
