Need Advice: CS350-LS GW score has holes in the cabs
Zentish
I've been looking for an upgrade to my CS245i but wanted to be sure it matched my RTA 8TL's, which the 245i does a decent job of. A CS350-LS went up on ebay this week from my local GW and I picked it up for $83.
I got it home and benched it and it sounds quite nice and I can't wait to get my 245i swapped out. The grill looks good, the drivers all work, it sounds very sweet to my ears in the garage.
One small problem with the 350 is some strange - I assume - mounting hardware on the back along with extra holes (12 holes in all) that appear to have been drilled all the way through the cabinet.
Q1: Does anyone know anything about these strange balls mounted on the back corners and what they might be for?
Q2: What advice do folks have for filling in the screw holes on the back? I saw a few posts about using Elmers wood wood patch and toothpicks. I have some hardwood floor patch, would that work as well?
THANKS!
THANKS!
Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87
Center: Polk CS245i
Console: Xbox360
Some sort of mounting brackets.
You could simply put the screws back into the holes. Another option would be to use wood epoxy, not wood filler. You can get the non-pro version at Home Depot, comes in a roll. Cut off a piece and use water (sparingly) as a lube as you kneed it between your fingers. Once it's all the same color jam it into the holes. Use a putty knife dipped in water to force it in the holes and smooth the outer surface. That version takes 24 hours to reach a full cure at which point it's as hard as a rock.Political Correctness'.........defined
President of Club Polk -
I would first clean off all the burrs and raised ridges around the screw holes with a utility knife or single edge blade. Vacuum everything to remove and chips or sawdust.
Fill the holes with Loctite Power Grab. Squirt enough in each hole to fill it, then wipe off any excess with a damp sponge or rag. Let it set for 2-4 hours. It will shrink back and dry clear. After it's set, add a little dab to each hole to level the surface. Again wipe off any excess. I've filled many screw holes in this manner where they are not visible.Home Theater/2 Channel:
dhsspeakerservice.com/ -
You can also use JB weld kwik wood. It works pretty good. The other methods as stated in the above comments work exceptional too!
Nice center, I also have one.SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC -
The Loctite Power Grab worked quite well - thanks for the advice!
It seems my quick garage audition didn't reveal a flaw in one of the drivers. It took a few hours of listening for the left-hand mw4850 to exhibit a scratching sound. The speaker sounded fine up until then. Now I'm on a hunt for a replacement driver.Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Center: Polk CS245i
Console: Xbox360
Zone2: 2x Polk M5b '87 -
eBay is about the only place you'll find salvaged drivers. You can also try Polk Tech Support: 1-800-377-POLK (7655) Option 1. This is not the first time I've heard of this on the CS350-LS. I believe it may be our old nemesis, Magnet Shift. Try rotating the driver 180 degrees in the mean time.Home Theater/2 Channel:
Try and snag this pair of LS F/X surrounds - you'll have 4 extra tweeters an 4 drivers:-)
http://www.ebay.com/itm/Polk-Audio-LS-f-x-Bipole-Dipole-Wall-Surround-Speakers-CSM-Center-Speaker-/261964516544?pt=LH_DefaultDomain_0&hash=item3cfe4d4cc0“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
PM @ZLTFUL. He had a LS/fx he was selling
Hey Zentish, not sure if this could help you out.... but here it goes: http://www.ebay.com/itm/POLK-MW4851-Midrange-5-Woofer-Driver-Polk-Audio-Polk-LS-fx-/251909590306?pt=LH_DefaultDomain_0&hash=item3aa6fb4d22
Let us know, another option is to go and purchase the Ls/Fx that's on the bay. You'll have back-up drivers.SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
PS4
XBOX One
MIT Interconnects
BJC -
dust cap is crackedchefkungfu wrote: »Hey Zentish, not sure if this could help you out.... but here it goes: http://www.ebay.com/itm/POLK-MW4851-Midrange-5-Woofer-Driver-Polk-Audio-Polk-LS-fx-/251909590306?pt=LH_DefaultDomain_0&hash=item3aa6fb4d22
westmassguy wrote: »dust cap is crackedchefkungfu wrote: »Hey Zentish, not sure if this could help you out.... but here it goes: http://www.ebay.com/itm/POLK-MW4851-Midrange-5-Woofer-Driver-Polk-Audio-Polk-LS-fx-/251909590306?pt=LH_DefaultDomain_0&hash=item3aa6fb4d22
Your right about that! I jumped the gun on the link.... my mistake!
Sorry about that guys!SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
PS4
XBOX One
MIT Interconnects
BJC -
ken brydson wrote: »Try and snag this pair of LS F/X surrounds - you'll have 4 extra tweeters an 4 drivers:-)
Did you miss my post? Pretty sure Ryan still has a pair of LS/fx's...
